Discuss
Tested oven switch, little help with diagnosis
 in
This is a glass top range. The burner is a triple ring unit with a "powerboost" feature. So, if you
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tested oven switch, little help with diagnosis
  #1 (permalink)
Old 08-16-2010, 06:51 AM
Junior Member
JarekS is on a distinguished road
Default Tested oven switch, little help with diagnosis
Model Number: MER5775RCS   Brand: Maytag   Age: 1 - 5 years
So, if you turn the switch left, only the smallest ring should work. It doesn't. When I turn the switch to the right, the smallest and medium ring should work, once again the smallest ring doesn't work, the medium one does. In this position when I turn on the powerboost switch, the largest ring should turn on and it does. So basically the smallest ring never works.
Took out the switch, there doesn't seem to be any continuity between P1/S1 and 4 no matter if the switch is off, or on to the left or right. The other prongs have continuity. I find this odd since from the wiring diagram, it looks like there is power going through prong 4 since that's needed to light up the medium and large rings. Then again, my knowledge is limited, thus my post here.
I'd like to make sure it's the switch and not the burner and since this switch has the most complex wiring, I'd like some feedback if possible.
Here is the wiring diagram for it.
Any help will be appreciated, thank you.
Ads By Google
Related Models
Maytag MER5775RCS Range - S/c F/s Ele
Maytag MER5780BAB Range - S/c F/s Ele
Maytag MER5780BAQ Range - S/c F/s Ele
Maytag MER5780BAS Range - S/c F/s Ele
Maytag MER5780BAW Range - S/c F/s Ele
Maytag MER5870AAA Range - S/c F/s Ele
Maytag MER5870AAB Range - S/c F/s Ele
Maytag MER5870AAQ Range - S/c F/s Ele
Maytag MER5870AAW Range - S/c F/s Ele
Maytag MER5870ACA Range - S/c F/s Ele
Maytag MER5870ACB Range - S/c F/s Ele
Maytag MER5870ACW Range - S/c F/s Ele
Maytag MER5870BAB Range - S/c F/s Ele
Maytag MER5870BAQ Range - S/c F/s Ele
Maytag MER5870BAW Range - S/c F/s Ele
Maytag MER5870BCQ Range - S/c F/s Ele
Maytag MER5870BCS Range - S/c F/s Ele
Maytag MER5870BCW Range - S/c F/s Ele
Maytag MER5875QAB Range - S/c F/s Ele
Maytag MER5875QAF Range - S/c F/s Ele
Maytag MER5875QAN Range - S/c F/s Ele
Maytag MER5875QAS Range - S/c F/s Ele
Maytag MER5875QCB Range - S/c F/s Ele
Maytag MER5875QCF Range - S/c F/s Ele
Maytag MER5875QCS Range - S/c F/s Ele
Maytag MER5875QCW Range - S/c F/s Ele
Maytag MER5875RAB Range - F/s Std Ele
Maytag MER5875RAF Range - F/s Std Ele
Maytag MER5875RAN Range - F/s Std Ele
Maytag MER5875RAS Range - F/s Std Ele
Maytag MER5875RCB Range - S/c F/s Ele
Maytag MER5875RCF Range - S/c F/s Ele
Maytag MER5875RCQ Range - S/c F/s Ele
Maytag MER5875RCS Range - S/c F/s Ele
Maytag MER5875RCW Range - S/c F/s Ele
Maytag MER5880BAB Range - S/c F/s Ele
Maytag MER5880BAQ Range - S/c F/s Ele
Maytag MER5880BAS Range - S/c F/s Ele
Maytag MER5880BAW Range - S/c F/s Ele
Maytag MER6549BAQ Freestanding - Double Oven - Electric
Maytag MER6549BAW Freestanding - Double Oven - Electric
Maytag MER6550AAQ Freestanding - Double Oven - Electric
Maytag MER6550AAW Freestanding - Double Oven - Electric
Maytag MER6550ACQ Freestanding - Double Oven - Electric
Maytag MER6550ACW Freestanding - Double Oven - Electric
Maytag MER6550BAQ Freestanding - Double Oven - Electric
Maytag MER6550BAW Freestanding - Double Oven - Electric
Maytag MER6550BCQ Freestanding - Double Oven - Electric
Maytag MER6550BCW Freestanding - Double Oven - Electric
Maytag MER6555AAB Freestanding - Double Oven - Electric
Maytag MER6555AAQ Freestanding - Double Oven - Electric
Maytag MER6555AAW Freestanding - Double Oven - Electric
Maytag MER6555ACW Freestanding - Double Oven - Electric
Maytag MER6741BAB Freestanding - Double Oven - Electric
Maytag MER6741BAS Freestanding - Double Oven - Electric
Maytag MER6741BAW Freestanding - Double Oven - Electric
Maytag MER6750AAB Range - Accellis 2x
Maytag MER6750AAC Range - Accellis 2x
Maytag MER6750AAQ Range - Accellis 2x
Maytag MER6750AAS Range - Accellis 2x
Maytag MER6750AAW Range - Accellis 2x
Maytag MER6750ACC Range - Accellis 2x
Maytag MER6750ACQ Range - Accellis 2x
Maytag MER6750ACW Range - Accellis 2x
Maytag MER6751AAB Freestanding - Double Oven - Electric
Maytag MER6751AAQ Freestanding - Double Oven - Electric
Maytag MER6751AAS Freestanding - Double Oven - Electric
Maytag MER6751AAW Freestanding - Double Oven - Electric
Maytag MER6755AAB Freestanding - Double Oven - Electric
Maytag MER6755AAQ Freestanding - Double Oven - Electric
Maytag MER6755AAS Freestanding - Double Oven - Electric
Maytag MER6755AAW Freestanding - Double Oven - Electric
Maytag MER6755ACB Freestanding - Double Oven - Electric
Maytag MER6755ACS Freestanding - Double Oven - Electric
Maytag MER6755ACW Freestanding - Double Oven - Electric
Maytag MER6765BAB Freestanding - Double Oven - Electric
Maytag MER6765BAQ Freestanding - Double Oven - Electric
Maytag MER6765BAS Freestanding - Double Oven - Electric
Maytag MER6765BAW Freestanding - Double Oven - Electric
Maytag MER6769BAQ Freestanding - Double Oven - Electric
Maytag MER6769BAW Freestanding - Double Oven - Electric
Maytag MER6770AAB Freestanding - Double Oven - Electric
Maytag MER6770AAC Freestanding - Double Oven - Electric
Maytag MER6770AAQ Freestanding - Double Oven - Electric
Maytag MER6770AAW Freestanding - Double Oven - Electric
Maytag MER6770ACB Freestanding - Double Oven - Electric
Maytag MER6770ACC Freestanding - Double Oven - Electric
Maytag MER6770ACQ Freestanding - Double Oven - Electric
Maytag MER6770ACW Freestanding - Double Oven - Electric
Maytag MER6771AAB Freestanding - Double Oven - Electric
Maytag MER6771AAC Freestanding - Double Oven - Electric
Maytag MER6771AAQ Freestanding - Double Oven - Electric
Maytag MER6771AAW Freestanding - Double Oven - Electric
Maytag MER6772BAB Freestanding - Double Oven - Electric
Maytag MER6772BAC Freestanding - Double Oven - Electric
Maytag MER6772BAQ Freestanding - Double Oven - Electric
Maytag MER6772BAS Freestanding - Double Oven - Electric
Maytag MER6772BAW Freestanding - Double Oven - Electric
Maytag MER6772BCB Freestanding - Double Oven - Electric
Maytag MER6772BCQ Freestanding - Double Oven - Electric
Maytag MER6772BCS Freestanding - Double Oven - Electric
Maytag MER6772BCW Freestanding - Double Oven - Electric
Maytag MER6775AAB Freestanding - Double Oven - Electric
Maytag MER6775AAF Freestanding - Double Oven - Electric
Maytag MER6775AAN Freestanding - Double Oven - Electric
Maytag MER6775AAQ Freestanding - Double Oven - Electric
Maytag MER6775AAS Freestanding - Double Oven - Electric
Maytag MER6775AAW Freestanding - Double Oven - Electric
Maytag MER6775ACB Freestanding - Double Oven - Electric
Maytag MER6775ACF Freestanding - Double Oven - Electric
Maytag MER6775ACS Freestanding - Double Oven - Electric
Maytag MER6775BAB Freestanding - Double Oven - Electric
Maytag MER6775BAF Freestanding - Double Oven - Electric
Maytag MER6775BAN Freestanding - Double Oven - Electric
Maytag MER6775BAS Freestanding - Double Oven - Electric
Maytag MER6870AAB Freestanding - Double Oven - Electric
Maytag MER6870AAC Freestanding - Double Oven - Electric
Maytag MER6870AAQ Freestanding - Double Oven - Electric
Maytag MER6870AAW Freestanding - Double Oven - Electric
Maytag MER6870ACC Freestanding - Double Oven - Electric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with Maytag diagnosis Earls's Wrench Washer Repair 3 02-19-2011 03:37 PM
replaced/tested lots still no heat oootwigzooo Dryer Repair 1 07-25-2010 02:45 AM
Whirlpoo Dryer won't heat, tested most parts everythingman Dryer Repair 1 08-09-2009 09:32 PM
Tested Rotary Switch bdrg Dryer Repair 1 01-15-2009 02:08 PM
