I need to install a new hinge assembly and according to the diagrams, it looks like I need to replace the 'support rivet' too (they're both bent)... problem is, I can't get the hinge out so I don't know how to replace.
I've taken the door off and unscrewed the 2 screws on the hinge but everything I read says to remove bottom drawer and disconnect assembly from underneath however, I can't remove the bottom drawer because it's a second oven.
Any insight is appreciated. Thanks!
HINGE ASSEMBLY: WB10K12 SUPPORT RIVET: WB10K10010 Model: PGB928SEM1SS
