Discuss
Amana Gas Range turns off unpredictably
 in
I've had the Amana ARGS7650E gas range for 13 years, and once had to replace the control module during warranty
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana Gas Range turns off unpredictably
  #1 (permalink)
Old 08-13-2010, 12:57 PM
Junior Member
Ray Theon is on a distinguished road
Default Amana Gas Range turns off unpredictably
Model Number: ARGS7650E   Brand: Amana   Age: More than 10 years
I've had the Amana ARGS7650E gas range for 13 years, and once had to replace the control module during warranty period. In the past few months the oven will turn itself off completely while baking, particularly at higher temps or when on for a longer time. The clock will reset, as if I pulled the plug. No F codes or anything -- just temporary loss of power, and then I can reset by pressing bake again. Is this a sign of another bad control module or a bad temperature sensor? The oven has not been keeping an accurate temp lately, when it does work. If it's a bad temperature sensor, can I (a repair novice) replace this myself? How?
Related Models
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NL RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NW RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 08-13-2010, 01:43 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
There are 2 versions of that particular range.
One has a cooling fan and thermostat to turn the fan on.
The other has a fan and thermostat to turn on the fan, and it also has a hi limit thermostat(on the back of the oven cavity).
I think you have a weak hi limit themostat,or the cooling fan is not comming on.
The temp sensor could be failing/weak,but that doesn't shut the unit down.
Could you get us the "P" number, off the serial plate, so we can be more accurate in assisting you.
Appreciate it.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-13-2010, 06:09 PM
Junior Member
Thanks for your reply! My oven has a cooling fan that seems to run properly when the oven is very hot and on for a long period... and it will continue to run even after the oven is off, but still hot. It may also have the high limit sensor you mentioned in the back of the oven cavity... I'm not sure about that. The "P" number is : P1130755N E and the Model is ARGS7650E, and it's gas.
Thanks!
Ray Theon
  #4 (permalink)
Old 08-16-2010, 08:08 AM
Senior Expert
Default
Thanks!
Ray Theon
Ray,
Thanks for the "p" number,
It made things a lot easier.
You actually have all 3 components, cooling fan, fan limit switch and a High limit switch.
(see attached)
Part number: AP4041090
The information you just gave me, tells me everything is working as designed, except the hi limit switch.
On your unit it is located on the top, left side of the oven cavity(under the cooktop).
It's still easier to access the thermostat from the back, instead of through the top of the unit.
(you may need a "stubby" screwdriver or nut driver).
Once you replace the limit switch, you'll be fine.
Good luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 10-22-2010, 10:51 AM
Junior Member
mr_ton is on a distinguished road
Default Same problem with an Amana ACS3350AS
I have exactly the same problem with my Amana ACS3350AS. When the oven heats up the control panel just goes blank and the oven turns off. When the oven cools down again it resets the control panel and it works again, but this means I can only have my oven on for 5-10 minutes.
I see that the control panel for this model is discontinued, so I was hoping there was another way to fix this problem.
Thanks,
James
  #6 (permalink)
Old 10-22-2010, 11:40 AM
Senior Expert
Default
Thanks,
James
James,
Have you done the checks that we reccomended on the previous posts ?
You have two limit switches under the cooktop, and a cooling fan, just like before (Ray).
Part number: AP4041226
You need to check and see which limit switch is open when the display goes blank. (or replace both).
You also need to make sure the cooling fan motor runs.
Good Luck,
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 11-09-2010, 05:23 PM
Junior Member
Default
OK, so I took the stove top off and turned the oven on full. I left it on for about an hour but it didn't turn itself off as normal. I could not hear a cooling fan and have not heard anything since, so I assume this is certainly broken. I checked the voltage across the 2 switches: the one that was further forward was 110V, the back one was 0V.
Do I just need to fix the fan or do the switches control the fan (do you know where I can find a wiring diagram)? I am guessing that because the top was off, the switches didn't get hot enough to trip. When I put the stove top back on it did turn itself off again as before (although it seemed to take longer that before).
Thanks,
James
  #8 (permalink)
Old 11-10-2010, 06:57 AM
Senior Expert
Default
Thanks,
James
James,
The fan limit switch controls the power to the cooling fan.
The control limit switch,(oven limit), of course is power to the control.
They are both temperature sensitive,
The fan limit closes and sends voltage to the cooling fan, when the temperature reaches a certain temp.in the burner box area, to cool the controls.
The control limit opens when it is too hot and turns off power to the control board and things go blank and inoperative.
You could test the cooling fan by jumping out the fan limit and see if the fan runs at the proper speed.
Or attach 120 VAC directly to motor and check it's operation.
I used to replace both limits at the same time, as long as the fan checked OK.
I'm sending the tech sheet for your unit, and you should be able to handle it from there.
Good Luck,
__________________
Joe M. APP TEAM
  #9 (permalink)
Old 11-24-2010, 10:14 AM
Junior Member
jkoelbel is on a distinguished road
Default Amana blank display / shuts down
I have a similar problem with the Amana ACS3350AS. After being on for an hour or more the display sometimes quits and then the oven shuts down. I don't think there is any cooling fan for this model - is there some other reason it is getting too hot?
  #10 (permalink)
Old 11-24-2010, 11:53 AM
Senior Expert
Default
Quote:
J,
There is a cooling fan / blower on your unit,
Part number: AP4280271
It is located on the back of the range( you'll need to pull the range out and remove the back panel to access it.
I would not start there, I've replaced more limit switches, than fans, over the years.
As the previous posts stated, both limits are located under the cooktop, on the left side of the burner box.
I always replaced both, if one is weak, so is the other.
But, the fan limit switch is a open circuit when the control area/cooktop temperature is below 155 dgrs. at 155 dgrs the limit switch closes and turns on the fan.
The oven/control limit is a closed circuit until the area temperature reaches 240 dgrs. the the limit opens and the control shuts down.
Basically everything mentioned it the previous posts, applies to your unit, follow the same process and procedures, and you'll be up and running, trouble free.
I included the part numbers for your unit.
Good Luck.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Convection Oven comes on for 10 sec. and turns off tommagner Oven Repair (including Ranges and Cooktops) 2 08-20-2011 09:23 AM
Amana Microwave Turns off after a couple minutes Andre_K Microwave Repair 0 11-24-2009 08:46 AM
Maytag Gas Range Turns Itself On vjs Oven Repair (including Ranges and Cooktops) 6 09-02-2009 06:27 PM
Range/Oven turns off bknelms Oven Repair (including Ranges and Cooktops) 3 07-26-2009 06:31 PM
amana elec wall oven turns off amana98 Oven Repair (including Ranges and Cooktops) 1 08-27-2008 06:19 PM
