Discuss
Amana Gas Range turns off unpredictably
 in
Originally Posted by Joe / APP Team Ray, Thanks for the "p" number, It made things a lot easier. You
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Amana Gas Range turns off unpredictably
  #11 (permalink)
Old 07-11-2011, 02:28 AM
Junior Member
Ray Theon is on a distinguished road
Default
Quote:
Originally Posted by Joe / APP Team View Post
Ray,
You actually have all 3 components, cooling fan, fan limit switch and a High limit switch.
(see attached)
Part number: AP4041090
The information you just gave me, tells me everything is working as designed, except the hi limit switch.
On your unit it is located on the top, left side of the oven cavity(under the cooktop).
It's still easier to access the thermostat from the back, instead of through the top of the unit.
(you may need a "stubby" screwdriver or nut driver).
Once you replace the limit switch, you'll be fine.
Good luck,
i FINALLY replaced the high limit sensor, as you suggested! It was sitting in a box for a year after I ordered it! (My wife finally said fix it, or I'm buying a new $4000 stove). Well, after I installed the high limit sensor neither the oven or broiler will light or do anything! The regular burners work fine, and there is gas flowing to the unit. Before the "repair" it took about 5 minutes for the oven to light. It would just sit there thinking about whether it wanted to light for 5 minutes. Now, it won't light at all. What is my next repair Sir, to fix this problem?
  #12 (permalink)
Old 07-11-2011, 08:36 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Ray,
Disconnect the wire harness from the bake and/or broil igniter. Program a cycle. and check for 120 VAC in the connector from the cabinet wire harness for the igniter. If you have the voltge, you'll need to check for 3.2 to 3.6 VAC at the burner valve, across the wires that come from the igniter to the valve. Low or no voltage at the gas valve terminals, would indicate a weak or broken igniter, and the switch will not open to release the gas and ignite.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 06-25-2012, 05:28 PM
Junior Member
davidium is on a distinguished road
Default Part discontinued - AP4280271/Y0308607
The part mentioned in the forum, AP4280271 or manufacturer number Y0308607, is no longer offered by most retailers. What would you recommend as a way to fix the stove if that part is broken? Can the transformer of motor be replaced as a subcomponent?
  #14 (permalink)
Old 06-26-2012, 07:32 AM
Senior Expert
Default
Quote:
David,
I guess the cooling fan is not running ? causing the range or control to shut down. Your best bet would be to keep searching the inter net, you have the manufacturer part number, Trying to rebuild a fan motor is probably not cost effective, or possible, unless you have access to a motor rebuild operation.
Good Luck and Thanks,
__________________
Joe M. APP TEAM
  #15 (permalink)
Old 06-26-2012, 10:18 AM
Junior Member
Default
David,
Joe, yes I replaced the two limit switches on the model ARGS7650WW and the fan motor still doesn't run. The two sub-components are the transformer and the actual motor and it will take a fair amount of time to try and find generic pieces for either. For such a small part, it's definitely been a beating to try and trouble shoot when the manufacturer ceases to support the stove model.
  #16 (permalink)
Old 06-26-2012, 12:36 PM
Senior Expert
Default
David, You may not have a fan motor issue. You may not be waiting long enough ? The fan limit switch is an "open" circuit until the area reaches a temp of 155 dgrs, the limit switch closes and allows 120 VAC to the fan motor and the fan runs and cools the control panel and area.
A couple of ways to check, Turn off power to the range, connect the Black and Yellow wires at the switch together, and re set power, the fan should run. Another way is to use a 120 VAC power test cord, attach the ends to the fan motor wires and plug the cord into an outlet, the fan motor should run.
I've attached the wiring diagram and tech sheet to this response, so you'll be able to test and check the components, and track the circuits.
Model ARGS7650WW
tech info for ARGS.pdf
Thanks Again,
__________________
Joe M. APP TEAM
  #17 (permalink)
Old 06-27-2012, 12:31 AM
Junior Member
Default
Joe, thanks for your patience. I did test the blower motor independently with a test cord into a wall outlet and it turned on so that's good. I put it back into the stove, put the stove panel back on and turned the oven on to 400. I waited to see if the low limit would flip and turn on the fan but it never came on. Additionally, the oven turned off again due to, and I'm guessing, the high limit switch flipping. Since I just replaced the limit switches, I'm not sure what else to do.
  #18 (permalink)
Old 06-27-2012, 09:08 AM
Senior Expert
Default
David,
With an oven temp of 400 dgrs, the cooling fan probably won't start or run for quite sometime. You're sure the thermostats are installed properly and in the correct position( hi limit is mounted closer to the front, the fan switch is closer to the back of the range). and are both rated witin 10 % of the original parts. You could try this, but be careful, Insert a very thin spacer(1/32 or 1/16 in.) under the thermostat mounting tabs, and see if it takes longer to open and shut the range control down.
Good Luck,
__________________
Joe M. APP TEAM
  #19 (permalink)
Old 07-03-2012, 09:03 PM
Junior Member
Default
Joe, after testing the switches, it looks like there is a problem with the oven exhaust vent going into the compartment where the switches and fan reside so that no matter how hard the blower works, eventually the full oven exhaust wins out and the oven limit flips. I'm trying to figure out how to tweak the vent because the vent is very long but extremely thin(perhaps 1/3 inch) and if the top panel isn't fitting it correctly, then the oven exhaust is partially diverted into the space between the range top and the oven. Any tips? All screws and the gas range outlets are lining up just fine.
  #20 (permalink)
Old 07-04-2012, 06:31 AM
Senior Expert
Default
David,
That could be the issue. The end of the vent flue does need to be 1/8 to 1/4 inch up inside the vent cover on the top. You may want to check the oven vent and raise the flue slightly, and use some hi temp foil tape to seal the joints and seams.
Thanks Again
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Convection Oven comes on for 10 sec. and turns off tommagner Oven Repair (including Ranges and Cooktops) 2 08-20-2011 10:23 AM
Amana Microwave Turns off after a couple minutes Andre_K Microwave Repair 0 11-24-2009 09:46 AM
Maytag Gas Range Turns Itself On vjs Oven Repair (including Ranges and Cooktops) 6 09-02-2009 07:27 PM
Range/Oven turns off bknelms Oven Repair (including Ranges and Cooktops) 3 07-26-2009 07:31 PM
amana elec wall oven turns off amana98 Oven Repair (including Ranges and Cooktops) 1 08-27-2008 07:19 PM
