Discuss
Remove maintop from Thermador range
 in
I ordered a replacement control module and it came with some nice instructions. The first step is loosening the main
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Remove maintop from Thermador range
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-17-2007, 09:19 PM
daveoman daveoman is offline
Junior Member
daveoman is on a distinguished road
Default Remove maintop from Thermador range
Model Number: RDF30QW   Brand: Thermador   Age: More than 10 years
I ordered a replacement control module and it came with some nice instructions. The first step is loosening the main top. Well, 3 of the venturi tubes screwed out but the left front WILL NOT come out. Of course, now it's stripped beyond repair (and I've ordered a new one.) Any ideas about how to get it out?
Thanks.
-- Dave
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 02:58 PM
Junior Member
Default Finished!
For everyone else's benefit:
- I got the other venturi tube off using a spiral bolt extractor. You need a big one, but it worked like a charm (after putting a little liquid wrench in there.)
- You need a 20mm socket for that silly thing.
- If you order a replacement ect, you have to take the top off. This is accomplished by taking the venturi tubes out first. You then have all the access you need.
- The rest is a piece of cake!
  #3 (permalink)
Old 04-08-2008, 11:29 AM
DerekJ DerekJ is offline
Junior Member
DerekJ is on a distinguished road
Default Remove Top of GSC30CV
I had my display on my Thermador GSC30CV stop working. I could access the display and assumed that was the problem; however, the problem appears to be the power relay board. (I checked the voltage output at the display.) This appears to be located under the cook top and over the oven. How do I get to it? I appears to need a special tool to loosen the gas burners from the top, but I can't locate the tool. Any help would be appreciated.
  #4 (permalink)
Old 04-23-2008, 09:19 AM
Rowbum82 Rowbum82 is offline
Junior Member
Rowbum82 is on a distinguished road
Default
Quote:
My clock/timer display on my Thermador GSC30CV range has worked intermittently for years. It mostly goes off when the oven is hot, but other times as well. I found through trial and error that if I close the oven door hard, it usually comes on. Sometimes for just a short time and I have to do it repeatedly. I've wanted to repair it but I've only found one place with the replacement part and it's $486, and I've never been certain that the display itself is the problem. Given that heat causes it to cut out, sounds like I may have the same issue as you described with the power relay board. Where did you find that part? Did you ever get advice on the right tool to loosen the burners?
  #5 (permalink)
Old 09-02-2008, 08:32 AM
Bats Bats is offline
Junior Member
Bats is on a distinguished road
Default Accessing Front Control Panel (clock & controls) GSC30CV
Quote:
I'm still trying to get the front panel off. Do I have to lift off the whole range top to get access to the 2-3" wide control panel that runs across the whole front of the range, above the oven?
My problem is intermittent failure of oven control; I'm hoping a good cleaning of the harness will fix it. All suggestions welcome.
  #6 (permalink)
Old 09-19-2008, 05:44 PM
egizzi egizzi is offline
Junior Member
egizzi is on a distinguished road
Default Similar Success
I wanted to second Daveoman's experience. Two of my venturi burners were frozen. I tried everything, including a propane blowtorch followed by ice. I bought one of those "gator-grips" after stripping the bolt heads but I couldn't budge the thing. Finally I went to my local tool lending library and borrowed a spiral screw extractor. There is no size indicator on it, but it is big. You want the first part of the extractor to enter the hole in the bolt and descend a little before it catches on the inside of the bolt as the extractor widens. I then took a vise-grip and twisted it clockwise. After several turns, I had to switch to an adjustable crescent wrench and after a couple of counter-clockwise tugs, voila, the bolt was loose.
Some suggestions:
1) Buy replacement o-rings for all the burners. Yours are probably dried and cracked like mine were
2) I put some Inox Lubricant on the Venturi Burner threads before I put them back on. Whether that makes a difference the next time I have to open the stove up, I don't know.
3) To get the screw extractor out of the bolt, I put base of the screw extractor in a large vise, and took my deep 20 mm socket and turned counter clockwise and the bolt separated from the extractor
Now my display is so bright, I have to wear sunglasses.
-E
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Cooktop Sparking Matt Schauer Oven Repair (including Ranges and Cooktops) 14 08-15-2008 05:35 PM
Thermador display is very dim gtbdevs Oven Repair (including Ranges and Cooktops) 17 06-07-2008 04:26 PM
how to replace igniter on thermador gas grill cosomactoo Oven Repair (including Ranges and Cooktops) 1 09-19-2007 07:24 PM
Can't remove top BoyBlue Dryer Repair 1 08-20-2007 11:49 AM
Thermador Free Standing Range SpaceAce Oven Repair (including Ranges and Cooktops) 1 08-14-2007 12:28 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
