I just received the new baking element for my oven I ordered from AppliancePartsPros.com. The old bad one has screw terminals. The new replacement has 1/4" push on terminals. I called the toll free number and they confirmed the catalog says that P/N Whirlpool 326791 is the correct replacment for my Model.
Question #1 Is there a recommended set of screw/push adapters I can buy?
Question #2 If I have to remove the wire end ring terminals and replace them with push terminals I will need to know the rated amperage of the terminals. Does anyone know the electrical amp rating for these terminals?
I can't believe that there isn't a well known solution for my predicament! Help! :eek: I can't cook my dinner in the oven tonight. I'll have to fire up the grill in the rain.
