Discuss
Bruce
 in
Oven cuts off 200 degrees prior to desired temperature. I have relpaced glow coil igniter and thermostat, however this has
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bruce
  #1 (permalink)
Old 08-28-2008, 01:02 PM
Junior Member
Bruce Hathaway is on a distinguished road
Unhappy Bruce
Brand: Hardwick   Age: 5 - 10 years
Oven cuts off 200 degrees prior to desired temperature. I have relpaced glow coil igniter and thermostat, however this has not fixed the problem.What can I do now?
Ads By Google
  #2 (permalink)
Old 08-29-2008, 12:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Bruce,
What is the complete model number of the oven?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-01-2008, 11:47 AM
Junior Member
Default Bruce
Gene,Thanks for the reply. The Model # CPG9841 W689DQ
  #4 (permalink)
Old 09-02-2008, 01:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Bruce Hathaway View Post
... I have replaced glow coil igniter and thermostat...
Hi Bruce,
Which part did you call "thermostat"? What is the reference number for this part on the break down diagram?
Did you check the oven sensor resistance? It suppose to be about 100 Ohms at the room temperature.
Here are the break down diagrams for the Hardwick range Model CPG9841W689DQ
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bruce xeagerx Dryer Repair 0 02-11-2010 08:15 AM
Ken Bruce kwbruce Oven Repair (including Ranges and Cooktops) 0 10-22-2009 08:39 AM
Bruce BBOYLE Washer Repair 1 09-30-2009 07:35 AM
Bruce brucecanner Microwave Repair 0 11-14-2008 09:46 AM
Bruce Bramsey Oven Repair (including Ranges and Cooktops) 0 11-21-2007 01:09 PM
