On the gas stovetop with the XLO side one burner works the other doesn't. It sparks but will not create any flame. It seems there is no gas coming out of it. It is the front burner. The back burner works fine. The stove is super clean, no obstructions, just will not take the spark and light. Why isn't it giving any gas?
On a side note, the front panel all of a sudden stopped working, no timer, no bake, no broil. Had a certified service guy out. Said the front control panel needed to be fixed. Said to junk the stove, it wasn't worth fixing. A $5000 stove not worth fixing? So, googled the problem. There was a forum with many of the same problems. One guy said shutting down the power to the unit for 5 minutes usually will reset the controls. Nothing to loose, so shut it down. When I powered it back up, magic, it works like a charm...
Anyway, appreciate any input on this seemingly little problem of the burner not getting gas... Thanks.
