Discuss
Whirlpool Gold - Dual burner stuck on high
 in
I have a Whirlpool Gold AccuBake 465 smooth top range. I have a dual burner on the front left that
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Gold - Dual burner stuck on high
  #1 (permalink)
Old 08-11-2010, 12:48 PM
Junior Member
kheg is on a distinguished road
Default Whirlpool Gold - Dual burner stuck on high
Brand: Whirlpool   Age: 5 - 10 years
I have a Whirlpool Gold AccuBake 465 smooth top range. I have a dual burner on the front left that has gotten stuck on high. No matter if I turn it on the lowest setting, it heats to high. Usually the burners will turn red and fade in and out as the burner is on and heating. Now I notice the burner stays lit the whole time. Can anyone offer help on how my handy husband can look into fixing this for me?
Thanks so much for any help you can offer.
  #2 (permalink)
Old 08-11-2010, 01:32 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
You probably have a stuck or shorted infinite burner switch.
But we need a model number to research and varify that.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-11-2010, 01:44 PM
Junior Member
Default Model # for Whirlpool Gold w/ Stuck dual burner
I looked the range all over before I could find that model number! Finally, I found the sticker and it is: model GR460LXKT
If it is a infinite burner switch, is this accessed from the rear panel?
Thanks again!!
  #4 (permalink)
Old 08-11-2010, 03:13 PM
Senior Expert
Default
Thanks again!!
You can access it from the back, but thats the hard way to go.
Actually, you access it from the front of the control panel.
First , turn off the power to the unit, or unplug the power cord
Remove the screws across the top back, and the bottom corner front screws and "peel" the panel off towards the front.
Remove the knob and the 2 screws, that hold the switch to the panel
Switch wires, 1 at a time, and reverse procedure to reinstall panel and test.
I believe this will be the switch you need.
Part number: AP3086276
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 08-11-2010, 03:15 PM
Junior Member
Smile Great, Thanks Joe
Thanks, Joe for your help. I will show this info to my husband when he gets home tonight! Hope this takes care of it!!
  #6 (permalink)
Old 08-12-2010, 09:07 AM
Senior Expert
Default
As long as there's no broken or shorted wires,
I'm sure the new switch will solve the problem.
If you (he) need us again,
Don't hesitate to drop us a line.
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 11-27-2010, 09:47 AM
Junior Member
PKJohnson is on a distinguished road
Default Whirlpool Accubake Duo 465 Dual burner stuck on high
Joe M. APP TEAM,
I have a model # GR460LXKT with a dual burner issue. While on low (2) continues to heat at high.
Removed the back cover and found Inf-switch (blue) with part number 8522887 stamped on it. What is the correct switch to order, AP3777761 (blue) or AP3086276?
Best regards,
PKJohnson
  #8 (permalink)
Old 11-29-2010, 07:37 AM
Senior Expert
Default
Quote:
Originally Posted by PKJohnson View Post
Joe M. APP TEAM,
I have a model # GR460LXKT with a dual burner issue. While on low (2) continues to heat at high. Removed the back cover and found Inf-switch (blue) with part number 8522887 stamped on it. What is the correct switch to order, AP3777761 (blue) or AP3086276?
Best regards,
PKJohnson
PK,
Your dual element switch for the Left Front element should be,
Part number: AP3777761
Remember:
***Turn power off to the range,***
Remove the knob and switch for the panel,
Switch wires from the old, to the new switch,
Install new switch to control panel,
Restore power and test burner/switch operation.
Good Luck,
__________________
Joe M. APP TEAM
  #9 (permalink)
Old 11-30-2010, 04:05 PM
Junior Member
Default
Thank you Joe M. Happy Holidays!
Patrick
  #10 (permalink)
Old 12-01-2010, 06:58 AM
Senior Expert
Default
Patrick
Patrick,
You're quite welcome,
It was a pleasure to help,
Happy Holidays to you as well,
Joe M.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Elctric Range - Dual Burner gets excessively hot! axrowland Oven Repair (including Ranges and Cooktops) 1 12-17-2009 04:21 PM
Whirlpool Electri 445 Dual burner gets excessively hot twilliams Oven Repair (including Ranges and Cooktops) 0 10-11-2009 04:29 PM
Whirlpool Accubake Dual burner overheats Kevin Duperron Oven Repair (including Ranges and Cooktops) 0 09-21-2009 05:28 PM
Whirlpool Accubake dual burner problem jwilso Oven Repair (including Ranges and Cooktops) 1 02-04-2009 12:52 PM
dual element stuck on high hi-ranger Oven Repair (including Ranges and Cooktops) 1 12-12-2008 04:02 PM
