| » Whirlpool Gold - Dual burner stuck on high |
Quote:
Is this the same infinite switch replacement? Ads By Google |
Quote:
Yes, the infinite control switch is the most likely issue, based on your post description. If your range has the sane model number, and the issue is in the left rear "dual" burner, then yes, the switch posted here will solve the issue. If you prefer, supply us wih the model number of your range and which burner is at fault, and we'll be happy to research, and advise you of the correct part number needed. Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Whirlpool Elctric Range - Dual Burner gets excessively hot! | axrowland | Oven Repair (including Ranges and Cooktops) | 1 | 12-17-2009 04:21 PM |
| Whirlpool Electri 445 Dual burner gets excessively hot | twilliams | Oven Repair (including Ranges and Cooktops) | 0 | 10-11-2009 04:29 PM |
| Whirlpool Accubake Dual burner overheats | Kevin Duperron | Oven Repair (including Ranges and Cooktops) | 0 | 09-21-2009 05:28 PM |
| Whirlpool Accubake dual burner problem | jwilso | Oven Repair (including Ranges and Cooktops) | 1 | 02-04-2009 12:52 PM |
| dual element stuck on high | hi-ranger | Oven Repair (including Ranges and Cooktops) | 1 | 12-12-2008 04:02 PM |
