| » Replacing potentiometer kit |
Model Number: SGCS304RS Brand: Thermador Age: 5 - 10 years
I have prchased the new Potetiometer kit due to no gas to one of the burners. How do I get the top of the cook top open to replace the Kit?
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for THERMADOR SGCS304RS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thanks in advance for your help with this. Kipp |
Quote:
__________________
You have to use a socket wrench to unscrew them. You can try WD-40 to loose them easier. If it would not help, then you have to hacksaw the frozen brass nut off the venturi. Be advised that because the brass nut is a part of the venturi, most of the time it is not possible to remove the bottom part of the venturi from the jet holder. You'll have to replace such jet holder too.
__________________
Thank you Gene for your response,
I think I'm at the cutting off point. I only hope I have enough of the venturi to get a pipe wrench on it. I have a tool for woodworking made by "Fine" which with a metal blade I think I can get a cleaner cut without marking up the base ring so much. Dremel and Bosch make one too. Give one a try on your next job like this. You have a lot of control with these tools, not like a sawsall. Too bad the design isn't better for parts replacement. I think I'll be about halfway to a new cooktop by the time this is over. Cheers |
| Display Modes | |
| potentiometer for thermadore | vintech | Oven Repair (including Ranges and Cooktops) | 0 | 06-15-2010 03:56 PM |
| Potentiometer Kit | SftyMan | Oven Repair (including Ranges and Cooktops) | 0 | 05-05-2009 12:51 PM |
| XLO potentiometer | Craig2 | Oven Repair (including Ranges and Cooktops) | 0 | 03-11-2009 11:56 AM |
| potentiometer nla | rosendo | Oven Repair (including Ranges and Cooktops) | 3 | 02-03-2009 09:05 PM |
| Instructions on replacing potentiometer switch | gbumaga | Oven Repair (including Ranges and Cooktops) | 9 | 12-06-2007 01:46 PM |
