| » Electronic Oven control |
Model Number: GLES388DBA Brand: Frigidaire Age: 5 - 10 years
I have a frigidaire smooth top range model number GLES388DBA. A while back after a loss of power to my home, the ES500 electronic oven control (ECO) went black, none of the oven controls worked. I turned the power off, the ECO stayed black. The ceramic burners on the stove top all work. Figuring that the ECO had died, I ordered a new one and replaced it. The new EOC was black also and none of the controls would work. I verified that I have power to the EOC. Any suggestions as to what to do next?
Replacement parts for FRIGIDAIRE GLES388DBA Frigidaire/electric Range | AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../318045090.pdf I am assuming that you checked for power at P5-5 to P5-8 and saw 120 volts. I am sort of guessing on the above as it is not marked as power in for the control board power supply. I would disconnect all connectors to the control board except P5 and then see if the display will light up. Only other thing I can think of is that you received a bad board.
__________________
I checked P5-5 to P5-8 and saw 120 volts. I disconnected all the connectors except P5. The console did not light up. I contacted a local appliance repair business and paid them to come look at the oven control. The techician said that it was properly installed and that it had power. He surmised that the new board was bad. He stated that to his knowledge board failure is the only possible problem. I contacted the online parts house and they agreed to replace the board. I mailed it back to the parts house. I received the replacement board today and installed it. The console did not light up. I rechecked P5-5 to P5-8, had 120v. I checked L1 to L2IN had 220v. I checked L1 to L2OUT had nothing. I checked L2IN to L2OUT had 220v. I disconnected all connectors except P5. Board remained dark. I feel that the probability that I would get 2 bad circuit boards is very remote. I am stumped! Any suggestions? |
I rigged a way to hook 120v directly to P5 and P8 from a wall outlet. The oven control illuminated. This is true of my orginial and the replacment oven control.
However when it is installed in the range it does not lite up. There must be some other component failure preventing power to the control board. |
Quote:
===== do you fix the problwm? If yes, can u share how?=========== |
Blind luck resolved the probelm. What I did should not have fixed my problem but it did. Here goes.
On my oven control P5-14 and P5-15 connect to the temperature probe and thermal circuit breaker. There was a two wire plug that connected P5-14 and 15 to the temperature probe and circuit breaker. I disconnected the plug tried to jumper P5-14 to P5-15 at the plug. I did not have any alligator clips small enough to used so I rigged two cutoff nails into the plug and jumpered between them. No change. I was not confident that I had continuity between the nails, so I decided to cut the plug out of the circuit, strip the wires and twist the bare wires together to make the jumper. No change. Like a dummy, I cut the wires too short to reuse the plug. Not having a replacement plug, I used two cermanic wire nuts to reconnect the wires. When I powered the oven backup the electronic oven control lit up and has been working like a champ ever since. I checked continuity through the plug. It checked fine. I took the plug to my local appliance repair man, told him the tale and he checked continuity through the plug and said it was OK. He agreed with me that removing the plug from the circuit should have had no affect. I haven't got a clue as to what was wrong and I have no idea what fixed the problem. I hope my experience helps someone. Thanks all for your support. |
Quote:
Thank you, I will try your way this weekend and hope to give you a good result. Best regards, |
Quote:
Today I carefully checked the two flat ribbons from keypad (which is glueed to the frame), and found the 15-pin ribbon connector (from key pad to eoc has two ribbon, one is 15 pin with last three cut-off at half) other one is 12-pin withtwo line cut-ogg at half. I will attache the photo below. Is the 15-pin one the P5 ( please see my picture, it is marked P6 different from the 318045090 schematic attached with the range)? The last two lines ( counted from the 3 half line) apprantly has some burn mark especially the line 15 and little on 14. Since it's a flat thin ribbon, how do you cut it and make the solder or connecting? I believ you are not the dumb luck, you fixed the right P5(p6)-15 and P5(p6)-14, which I and believe I found it, just don't know how to get the broken ribbon lines re-connceted, can I soloder the ribbon? I tried to remove the ribbon, but I am no able to take the keypad from the frame, it's glue too tight to seperate. Anyone have fixed it, appreciated to give me more details. Thanks a lots. |
The electrical schematic I am using is numbered 318045090. It can be obtained at parts web site or found in a clear pocket on the back of the range.
Neither of the ribbon connectors is P5. P5 is the the connector with all the wires hooked to it at the top of your drawing. Your picture shows P5 pins 1-10 counting from the right of the photo. P5 pins 1-3 have no wires. P5-5 and P5-8 are 120v to the electronic oven control (EOC). P5-5 is a white wire, P5-8 is a black wire. If you follow all the wires into the range, you will find a 15 pin plug. Disconnect the plug and using the wire colors determine the location of P5-5 and 8. Using a two wire extension cord, I cut the female end off the cord, striped the wires and then hooked two small alligator clips to the wires. I clipped the clips to P5-5 and 8 and then plugged the male side of the cord into an outlet near the range. In my case, the EOC lit up and started alarming, telling me that that the EOC was OK. If it turns out that your EOC is bad, I have a replacement that I will send you for its cost plus shipping. I am stuck with the one I ordered, the parts house would not take it back. I hope this helps. |
| Display Modes | |
| I think I have a bad electronic oven control ?? | tinner | Oven Repair (including Ranges and Cooktops) | 4 | 02-17-2010 03:02 PM |
| Keypad - Electronic Oven Control | Dar | Oven Repair (including Ranges and Cooktops) | 0 | 01-10-2010 10:10 AM |
| Electronic Oven Control | andye | Oven Repair (including Ranges and Cooktops) | 4 | 12-15-2009 07:16 PM |
| electronic oven control | john leonhart | Oven Repair (including Ranges and Cooktops) | 1 | 05-04-2009 08:50 PM |
| Electronic Oven Control | Dennis Hanson | Oven Repair (including Ranges and Cooktops) | 0 | 02-12-2008 11:37 AM |
