Discuss
Burner heating indicator light won't go off
 in
The burning heating indicator light on my Roper oven (bare bones model -- number not known) stays on even when
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner heating indicator light won't go off
  #1 (permalink)
Old 08-10-2010, 05:28 AM
mml mml is offline
Junior Member
mml is on a distinguished road
Default Burner heating indicator light won't go off
Brand: Roper   Age: 5 - 10 years
The burning heating indicator light on my Roper oven (bare bones model -- number not known) stays on even when the knobs are all off and the burners are cold. How do I fix this?
Ads By Google
  #2 (permalink)
Old 08-10-2010, 09:13 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
We can't be much help without a model number.
Does your stove have a glass cooktop or 4 individual burners.
Do you have 1 hot surface light or 4 individual lights ?
It would be best if you could find the model and serial number plate/tag.
(usually located on the lower side cabinet behind the lower panel,or when you open the oven door, along the top trim of the oven opening).
We can only generalize at this point.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-10-2010, 09:22 AM
mml mml is offline
Junior Member
Default
It's an older one, probably 8-10 years old. Four individual coil burners. One hot surface light.
  #4 (permalink)
Old 08-10-2010, 11:37 AM
Senior Expert
Default
You have 1 of 2 possible systems.
1) You should have 1 to 4 thermostat(s) in line with the hot surface light, one of those thermostats is stuck closed,and not resetting when the top is cool, or a wire is shorted.
2) If you have a glass cook top with "radiant burners" under the glass(may look like red coils,when on), each burner has a sensor and one of the sensors is stuck closed and not resetting when the top cools down.
That's as far as I can get you without a model number to check the wiring, circuitry and operation of the burners.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating Indicator Light Stuck On Bence Oven Repair (including Ranges and Cooktops) 0 05-08-2010 02:18 PM
Hot Surface Indicator Light Does Not Light Up! Help! musicew Oven Repair (including Ranges and Cooktops) 0 01-06-2010 10:14 PM
Indicator Light??? Burner Sensor???? mitchellres Oven Repair (including Ranges and Cooktops) 0 08-20-2009 06:16 PM
Burner doesn't work & hot indicator light stays on joaroe Oven Repair (including Ranges and Cooktops) 2 08-04-2009 08:12 PM
burner indicator light harego1 Oven Repair (including Ranges and Cooktops) 0 03-20-2008 11:21 AM
