Discuss
old magic chef gas stove leaking from burners
 in
okay, the burners are leaking, when i popped the top open, it seems the metal lines that connect to the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » old magic chef gas stove leaking from burners
  #1 (permalink)
Old 08-08-2010, 12:36 PM
Junior Member
thegreekmason is on a distinguished road
Default old magic chef gas stove leaking from burners
Model Number: 31203PAV   Brand: Magic Chef   Age: 5 - 10 years
okay, the burners are leaking, when i popped the top open, it seems the metal lines that connect to the burners are kinked and cracked. one of them has a noticeable split. where can i find parts for them? and if there are parts, is the replacement straight forward? you know, thread tape, flared ends, etc etc etc? oh wait, here is the model, the mrs just found the model number 31203PAV thanks all
Related Models
Magic Chef 31203PAV RANGE- F/S STD GAS
Magic Chef 31203SAA RANGE- F/S STD GAS
Magic Chef 31203SAW RANGE- F/S STD GAS
Magic Chef 31203WAA RANGE- F/S STD GAS
Magic Chef 31203WAW RANGE- F/S STD GAS
Magic Chef 3120SPA RANGE- F/S STD GAS
Magic Chef 3120SPW RANGE- F/S STD GAS
Magic Chef 3120SRA RANGE- F/S STD GAS
Magic Chef 3120SRW RANGE- F/S STD GAS
Magic Chef 31211SAA RANGE- F/S STD GAS
Magic Chef 31211SAW RANGE- F/S STD GAS
Magic Chef 31211WAA RANGE- F/S STD GAS
Magic Chef 31211WAM RANGE- F/S STD GAS
Magic Chef 31211WAV RANGE- F/S STD GAS
Magic Chef 31211WAW RANGE- F/S STD GAS
Magic Chef 31211XAA RANGE- F/S STD GAS
Magic Chef 31211XAS RANGE- F/S STD GAS
Magic Chef 31211XAW RANGE- F/S STD GAS
Magic Chef 31213SAA RANGE- F/S STD GAS
Magic Chef 31213SAW RANGE- F/S STD GAS
Magic Chef 31213WAA RANGE- F/S STD GAS
Magic Chef 31213WAM RANGE- F/S STD GAS
Magic Chef 31213WAV RANGE- F/S STD GAS
Magic Chef 31213WAW RANGE- F/S STD GAS
Magic Chef 31213XAA RANGE- F/S STD GAS
Magic Chef 31213XAW RANGE- F/S STD GAS
Magic Chef 3121SPA RANGE- F/S STD GAS
Magic Chef 3121SPW RANGE- F/S STD GAS
Magic Chef 3121SRA RANGE- F/S STD GAS
Magic Chef 3121SRW RANGE- F/S STD GAS
Magic Chef 3121STA RANGE- F/S STD GAS
Magic Chef 3121STW RANGE- F/S STD GAS
Magic Chef 3121WPA RANGE- F/S STD GAS
Magic Chef 3121WPV RANGE- F/S STD GAS
Magic Chef 3121WPW RANGE- F/S STD GAS
Magic Chef 3121WRA RANGE- F/S STD GAS
Magic Chef 3121WRV RANGE- F/S STD GAS
Magic Chef 3121WRW RANGE- F/S STD GAS
Magic Chef 3121WTA RANGE- F/S STD GAS
Magic Chef 3121WTV RANGE- F/S STD GAS
Magic Chef 3121WTW RANGE- F/S STD GAS
Magic Chef 3121XPA RANGE- F/S STD GAS
Magic Chef 3121XPS RANGE- F/S STD GAS
Magic Chef 3121XPW RANGE- F/S STD GAS
Magic Chef 3121XRA RANGE- F/S STD GAS
Magic Chef 3121XRA-UX RANGE- F/S STD GAS
Magic Chef 3121XRA-X RANGE- F/S STD GAS
Magic Chef 3121XRS RANGE- F/S STD GAS
Magic Chef 3121XRW RANGE- F/S STD GAS
Magic Chef 3121XRW-UX RANGE- F/S STD GAS
Magic Chef 3121XRW-X RANGE- F/S STD GAS
Magic Chef 3121XTA RANGE- F/S STD GAS
Magic Chef 3121XTS RANGE- F/S STD GAS
Magic Chef 3121XTW RANGE- F/S STD GAS
Magic Chef 3126SRA RANGE- F/S STD GAS
Magic Chef 3126SRW RANGE- F/S STD GAS
Magic Chef 3126STA RANGE- F/S STD GAS
Magic Chef 3126STW RANGE- F/S STD GAS
Magic Chef 3127STA RANGE- F/S STD GAS
Magic Chef 3127STW RANGE- F/S STD GAS
Magic Chef 3127WTA RANGE- F/S STD GAS
Magic Chef 3127WTV RANGE- F/S STD GAS
Magic Chef 3127WTW RANGE- F/S STD GAS
Magic Chef 3127XTA RANGE- F/S STD GAS
Magic Chef 3127XTW RANGE- F/S STD GAS
Magic Chef 31311SAA RANGE- F/S STD GAS
Magic Chef 31311SAW RANGE- F/S STD GAS
Magic Chef 31311WAA RANGE- F/S STD GAS
Magic Chef 31311WAW RANGE- F/S STD GAS
Magic Chef 31315VAM RANGE- F/S STD GAS
Magic Chef 31315VAV RANGE- F/S STD GAS
Magic Chef 31315VBM RANGE- F/S STD GAS
Magic Chef 31315VBV RANGE- F/S STD GAS
Magic Chef 31315WAM RANGE- F/S STD GAS
Magic Chef 31315WAV RANGE- F/S STD GAS
Magic Chef 31315XAA RANGE- F/S STD GAS
Magic Chef 31315XAW RANGE- F/S STD GAS
Magic Chef 31315XBA RANGE- F/S STD GAS
Magic Chef 31315XBW RANGE- F/S STD GAS
Magic Chef 3141XRA RANGE- F/S STD GAS
Magic Chef 3141XRW RANGE- F/S STD GAS
Magic Chef 3141XTA RANGE- F/S STD GAS
Magic Chef 3141XTW RANGE- F/S STD GAS
Magic Chef 3147XRA RANGE- F/S STD GAS
Magic Chef 3147XRA-X RANGE- F/S STD GAS
Magic Chef 3147XRW RANGE- F/S STD GAS
Magic Chef 3147XRW-X RANGE- F/S STD GAS
Magic Chef 3147XTA RANGE- F/S STD GAS
Magic Chef 3147XTW RANGE- F/S STD GAS
Magic Chef 3167VTV RANGE- F/S STD GAS
Magic Chef 3167VTW RANGE- F/S STD GAS
Magic Chef 3167VUV RANGE- F/S STD GAS
Magic Chef 3167XRA RANGE- F/S STD GAS
Magic Chef 3167XRA-X RANGE- F/S STD GAS
Magic Chef 3167XRW RANGE- F/S STD GAS
Magic Chef 3167XRW-X RANGE- F/S STD GAS
Magic Chef 3167XTA RANGE- F/S STD GAS
Magic Chef 3167XTA-X RANGE- F/S STD GAS
Magic Chef 3167XTW RANGE- F/S STD GAS
Magic Chef 3167XTW-X RANGE- F/S STD GAS
Magic Chef 3167XUA RANGE- F/S STD GAS
Magic Chef 3167XUA-X RANGE- F/S STD GAS
Magic Chef 3167XUW RANGE- F/S STD GAS
Magic Chef 3167XUW-X RANGE- F/S STD GAS
Magic Chef 3167XYA RANGE- F/S STD GAS
Magic Chef 3167XYW RANGE- F/S STD GAS
Magic Chef 3187VRA RANGE- F/S STD GAS
Magic Chef 3187VRV RANGE- F/S STD GAS
Magic Chef 3187VTA RANGE- F/S STD GAS
Magic Chef 3187VTV RANGE- F/S STD GAS
Magic Chef 3187VUA RANGE- F/S STD GAS
Magic Chef 3187VUV RANGE- F/S STD GAS
Magic Chef 3187XRA RANGE- F/S STD GAS
Magic Chef 3187XRW RANGE- F/S STD GAS
Magic Chef 3187XTA RANGE- F/S STD GAS
Magic Chef 3187XTW RANGE- F/S STD GAS
Magic Chef 3187XUA RANGE- F/S STD GAS
Magic Chef 3187XUW RANGE- F/S STD GAS
Magic Chef 31FA-1 RANGE- F/S STD GAS
Magic Chef 31FA-10 RANGE- F/S STD GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Gas Stove hkarpouzia Oven Repair (including Ranges and Cooktops) 0 06-13-2010 01:11 PM
magic chef stove not igniting Michael Robinson Oven Repair (including Ranges and Cooktops) 3 12-29-2009 02:09 PM
Magic Chef top burners won't click to spark flame bushump Oven Repair (including Ranges and Cooktops) 0 11-01-2009 06:59 AM
Magic Chef Stove w/ No Display. HELP!!! rdawkins411 Oven Repair (including Ranges and Cooktops) 0 06-23-2008 01:32 PM
Magic chef glass top stove not heating well chinadolls1021 Oven Repair (including Ranges and Cooktops) 1 09-10-2007 06:43 PM
