I got an error code F2 E6 and was told by Whirlpool to replace the control board which I did.
After replacing the board then the unit came up with SOME functionality. Not all the switches worked, then I got error code F2 E1. Should I replace the keypad? What would cause these types of problems? Would both parts go bad?
Thanks Ed
