Discuss
Thermador Cook N Vent CVS45RS Stuck in Up Position
 in
I normally can raise and lower the Cook N Vent snorkel and the vent fan always works. Occasionally though the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Cook N Vent CVS45RS Stuck in Up Position
  #1 (permalink)
Old 08-07-2010, 07:48 PM
Junior Member
scg0557 is on a distinguished road
Cool Thermador Cook N Vent CVS45RS Stuck in Up Position
Brand: Thermador   Age: 1 - 5 years
I normally can raise and lower the Cook N Vent snorkel and the vent fan always works. Occasionally though the snorkel will be stuck in the up position. I had replaced the on/off switch previously and have determined that the switch works properly and is not the issue. Now when the snorkel is stuck in the up position I have to take the J box cover off and then press against the com terminal on the gear motor switch slightly and release. Then I hit the on/off switch and the snorkel retracts. Its good for several cycles and then I have to repeat the above. Is it a bad gear motor switch?
Ads By Google
  #2 (permalink)
Old 08-08-2010, 07:44 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts, includes a wiring diagram
Replacement parts for THERMADOR CVS45RS | AppliancePartsPros.com
Yes it could be the switch.
Could also be that the switch is a little loose and is backing out so it does not close consistently.
Also bending the switch activation arm a little so it pushes the switch in further may solve this.
__________________
  #3 (permalink)
Old 01-16-2011, 01:45 PM
Junior Member
wgfrench is on a distinguished road
Default How to get to the micro switch
I'm pretty sure that my similar problem is a bad microswitch. But I can't quite figure how to disassemble enough to replace it or bend the arm.
Are there assembly/disassembly instructions on the web somewhere?
My mdoel is CVS30RB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Cook n Vent Fan Speed Switch jamesvalli Oven Repair (including Ranges and Cooktops) 4 03-26-2010 07:51 PM
Thermador Cook N' Vent M Mac Oven Repair (including Ranges and Cooktops) 0 12-17-2009 11:09 AM
Thermador cook n vent up-down switch bcody1 Oven Repair (including Ranges and Cooktops) 2 11-04-2009 10:43 PM
THERMADOR Cook N Vent Vent issue PaulaM Oven Repair (including Ranges and Cooktops) 0 06-25-2009 06:59 PM
Thermador Cook n vent Aninie Oven Repair (including Ranges and Cooktops) 1 01-02-2009 05:54 PM
