The broiler element I have is fried (broiled?), literally charcoal and breaking off in chunks. Do I need other parts, other than this element to replace it? There's something on the left side (facing in), like a wire or filament that may or may not have connected at one point to the element. Is that the case? Do I have to remove the upper braces that hold the element in order to replace it? The lower oven coil works as does the interior light. I read that I should : 1. Unplug unit. 2. Pull out old element (after removing braces?) and clip wires with clothespin to keep them from retracting/getting lost. 3. ??:confused: Broil element - Made by Whirlpool. 3-Loop oven broil element. Size: Width 11-3/4"; Length 14-7/8"; Mount bracket to terminals 3-7/8". Tab style mounting. Part Number: AP3077189 Made by WHIRLPOOL Read more: Part Details - WHIRLPOOL Broil element, part number: AP3077189 Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts [IMG]http://www.google.com/favicon.ico[/IMG]
