I'm replacing the pc board in my range and I'm having trouble with the instructions on the wire connections of the new board (EGO) replacing the old board (EAC). Not all of the labeled relay wires correspond with the wire color. The DLB1 wire is red, but the instructions indicate that it's blue and the L2-A wire is blue but the instructions indicate that it's red. Can someone help? Can I get a wiring diagram to check my connections.
