:) With all knobs in the off position the cooktop keeps clicking. Two of 4 burners are sparking when electricity is on . I had to kill the electricity at the breaker to make it stop. Thank you for your thoughts on what part(s) may need to be replaced
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Each knob has switch underneath that turns on the spark. One of these switches is bad or has gotten wet. If it happened after you cleaned the top or boiled something over it may dry out on its own in a couple of days. If the switch is bad you will need to replace it. Also with this brand you need the manufacture's number to look up parts.
