Discuss
tappan oven (smell gas but won't heat up)
 in
Help, trying to fix this appliance myself since i am out of work right now. had an estimate from a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » tappan oven (smell gas but won't heat up)
  #1 (permalink)
Old 08-03-2010, 11:57 AM
Junior Member
helgalai is on a distinguished road
Default tappan oven (smell gas but won't heat up)
Model Number: tgf355bxwa   Brand: Tappan   Age: 5 - 10 years
Help,
trying to fix this appliance myself since i am out of work right now. had an estimate from a handyman at over $200.00 yikes.
Problem for this gas stove is that the red/orange light is on in the oven but it is very slow to heat up, after 2 months of this, the oven now does not heat at all. I can smell the gas and the last time it heated up, i heard a small explosion in the oven. Can it be the ignition that needs to be replaced? How hard is that to do myself? Reading on line states it is not hard but i want to make sure that is what is wrong. Please help.
Helen
Related Models
Frigidaire TGF355BXWA Tap(v2) / Gas Range
Tappan TGF355CGSA GAS RANGE
Tappan TGF355CGSB GAS RANGE
Frigidaire TGF356BCDA Tap(v1) / Gas Range
Frigidaire TGF356BCDB Tap(v1) / Gas Range
Frigidaire TGF356BCDC Tap(v1) / Gas Range
Frigidaire TGF356BCDD Tap(v2) / Gas Range
Frigidaire TGF356BCDE Tap(v1) / Gas Range
Frigidaire TGF356BCWA Tap(v2) / Gas Range
Frigidaire TGF356BCWB Tap(v2) / Gas Range
Frigidaire TGF356BCWC Tap(v3) / Gas Range
Frigidaire TGF356BCWD Tap(v4) / Gas Range
Frigidaire TGF356BCWE Tap(v2) / Gas Range
Frigidaire TGF356CCSA Tap(v0) / Gas Range
Frigidaire TGF356CCSC Tap(v0) / Gas Range
Frigidaire TGF356CCSD Tap(v0) / Gas Range
Frigidaire TGF357BCDA Tap(v1) / Gas Range
Frigidaire TGF357BCDC Tap(v1) / Gas Range
Frigidaire TGF357BCDD Tap(v2) / Gas Range
Frigidaire TGF357BCDE Tap(v1) / Gas Range
Frigidaire TGF357BCWA Tap(v2) / Gas Range
Frigidaire TGF357BCWC Tap(v3) / Gas Range
Frigidaire TGF357BCWD Tap(v4) / Gas Range
Frigidaire TGF357BCWE Tap(v2) / Gas Range
Frigidaire TGF357CCSA Tap(v1) / Gas Range
Frigidaire TGF357CCSB Tap(v1) / Gas Range
Frigidaire TGF357CCSC Tap(v1) / Gas Range
Frigidaire TGF357CCSD Tap(v2) / Gas Range
Frigidaire TGF357CCSE Tap(v1) / Gas Range
Frigidaire TGF357CCSF Tap(v3) / Gas Range
Frigidaire TGF357CCSG Tap(v0) / Gas Range
Frigidaire TGF357CCTA Tap(v2) / Gas Range
Frigidaire TGF357CCTB Tap(v2) / Gas Range
Frigidaire TGF357CCTC Tap(v3) / Gas Range
Frigidaire TGF357CCTD Tap(v4) / Gas Range
Frigidaire TGF357CCTE Tap(v2) / Gas Range
Frigidaire TGF357CCTF Tap(v4) / Gas Range
Frigidaire TGF362BBBA Tap(v0) / Gas Range
Frigidaire TGF362BBBB Tap(v0) / Gas Range
Frigidaire TGF362BBBC Tap(v1) / Gas Range
Frigidaire TGF362BBBD Tap(v2) / Gas Range
Frigidaire TGF362BBBE Tap(v0) / Gas Range
Frigidaire TGF362BBBF Tap(v0) / Gas Range
Frigidaire TGF362BBBH Tap(v0) / Gas Range
Tappan TGF363AUA Tappan/range
Tappan TGF363AUB Tappan/gas Range
Tappan TGF363AUC Tappan/gas Range
Tappan TGF363AUD Tappan/gas Range
Tappan TGF363AUE Tappan/gas Range
Tappan TGF363AUF Tappan/gas Range
Tappan TGF363AWA Tappan/range
Tappan TGF363AWB Tappan/gas Range
Tappan TGF363AWC Tappan/gas Range
Tappan TGF363AWD Tappan/gas Range
Tappan TGF363AWE Tappan/gas Range
Tappan TGF363AWF Tappan/gas Range
Tappan TGF364AQA Tappan/range
Tappan TGF364AQB Tappan/range
Tappan TGF364AQC Tappan/gas Range
Tappan TGF364AQD Tappan/gas Range
Tappan TGF364AQE Tappan/gas Range
Tappan TGF364AQF Tappan/gas Range
Tappan TGF364AQG Tappan/gas Range
Tappan TGF364ASA Tappan/range
Tappan TGF364ASB Tappan/range
Tappan TGF364ASC Tappan/gas Range
Tappan TGF364ASD Tappan/gas Range
Tappan TGF364ASE Tappan/gas Range
Tappan TGF364ASF Tappan/gas Range
Tappan TGF364ASG Tappan/gas Range
Frigidaire TGF364SCDA Tap(v1) / Gas Range
Frigidaire TGF364SCWA Tap(v2) / Gas Range
Frigidaire TGF365BEDA Tap(v1) / Gas Range
Frigidaire TGF365BEDB Tap(v1) / Gas Range
Frigidaire TGF365BEDC Tap(v1) / Gas Range
Frigidaire TGF365BEWA Tap(v2) / Gas Range
Frigidaire TGF365BEWB Tap(v2) / Gas Range
Frigidaire TGF365BEWC Tap(v2) / Gas Range
Frigidaire TGF365BFDA Tap(v1) / Gas Range
Frigidaire TGF365BFWA Tap(v2) / Gas Range
Frigidaire TGF365CHSA Tap(v1) / Gas Range
Frigidaire TGF365CHSB Tap(v2) / Gas Range
Frigidaire TGF365CHSC Tap(v3) / Gas Range
Tappan TGF365CHSF Tappan/gas Range
Frigidaire TGF365CHTA Tap(v4) / Gas Range
Frigidaire TGF365CHTB Tap(v5) / Gas Range
Frigidaire TGF365CHTC Tap(v6) / Gas Range
Tappan TGF365CHTF Tappan/gas Range
Frigidaire TGF366CFBC Frg(v1) / Gas Range
Frigidaire TGF366CFSA Tap(v1) / Gas Range
Frigidaire TGF366CFSD Frg(v2) / Gas Range
Frigidaire TGF366CFSE Frg(v3) / Gas Range
Frigidaire TGF366CFTA Tap(v2) / Gas Range
Frigidaire TGF366CFTD Frg(v4) / Gas Range
Frigidaire TGF366CFTE Frg(v5) / Gas Range
Frigidaire TGF367CFSA Tap(v1) / Gas Range
Frigidaire TGF367CFTA Tap(v2) / Gas Range
Tappan TGF375BHBA GAS RANGE
Tappan TGF375BHBB GAS RANGE
Tappan TGF375BHBC GAS RANGE
Tappan TGF375BHBF Tappan/gas Range
Tappan TGF375CHSF Tappan/gas Range
Tappan TGF377WJCA Tappan/gas Range
Frigidaire TGF602PGD1 Tap(v0) / Gas Range
Frigidaire TGF602PGW1 Tap(v0) / Gas Range
Tappan TGF602PGW3 Tappan/gas Range
Tappan TGF602PGW4 Tappan/gas Range
Tappan TGF605EU1 Tappan/gas Range
Tappan TGF605EW1 Tappan/gas Range
Tappan TGF605EW2 Tappan/range
Frigidaire TGF605WCD1 Tap(v1) / Gas Range
Frigidaire TGF605WCD2 Tap(v1) / Gas Range
Frigidaire TGF605WCDA Tap(v2) / Gas Range
Frigidaire TGF605WCW1 Tap(v3) / Gas Range
Frigidaire TGF605WCW2 Tap(v2) / Gas Range
Frigidaire TGF605WCWA Tap(v4) / Gas Range
Frigidaire TGF605WFD1 Tap(v1) / Gas Range
Tappan TGF605WFD2 GAS RANGE
Tappan TGF605WFD4 GAS RANGE
Tappan TGF605WFD5 GAS RANGE
  #2 (permalink)
Old 08-03-2010, 03:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Helen,
Most likely the problem is a bad oven igniter. I'm assuming the problem is with the Bake mode, so this is the bottom igniter.
If you know how to handle a simple tools, this part is not too difficult to replace yourself. Remove the oven floor and the flame spreader.
- The oven igniter Part number: AP2150412
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-10-2010, 03:25 PM
Junior Member
Default
Gene,
My husband and son were able to fix my oven with the part you named in your original post. Thank you so much for your help. It was a pretty easy project for my son and husband to fix and they got some bonding time.
I do have a second question. How do I know if the self cleaning option is working in my Tappan oven. The model number was in my original email to you. Please help once again.
Helen
  #4 (permalink)
Old 08-10-2010, 04:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Helen. I'm glad you have such handy men in your family.
Quote:
...How do I know if the self cleaning option is working in my Tappan oven...
The easiest way to figure it out is to turn the self clean on.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Oven won't heat now Blackhawk141 Oven Repair (including Ranges and Cooktops) 3 04-20-2010 11:20 PM
Tappan Centennial: Foul smell oven vent-Elect Fire? ldjancik@sbcglobal.net Oven Repair (including Ranges and Cooktops) 0 12-31-2009 11:17 AM
Kenmore oven won't heat - gas smell lars30 Oven Repair (including Ranges and Cooktops) 2 01-28-2009 06:29 AM
Tappan oven won't heat mmartrano Oven Repair (including Ranges and Cooktops) 1 12-19-2008 04:55 AM
Oven Will not heat, no smell of gas bobafett2805 Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:11 AM
