successfully replaced igniter. should it continue to glow during burn phase or just until burner fires up?
thanks.
Originally Posted by: alicentexas successfully replaced igniter. should it continue to glow during burn phase or just until burner fires up?
thanks. The igniter does remain on after ignition. It should decrease in glow intensity, but stay on, in order to keep the amperage to the gas valve open and the burner on. Sounds like everything is working properly. Good job.
