Discuss
hot point range f2 error
 in
i have a hotpoint gas range that is running at a temperature well below what the erc is set at
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » hot point range f2 error
  #1 (permalink)
Old 08-21-2008, 02:51 AM
honeypot honeypot is offline
Junior Member
honeypot is on a distinguished road
Default hot point range f2 error
Brand: Hotpoint   Age: 1 - 5 years
i have a hotpoint gas range that is running at a temperature well below what the erc is set at and showing on the display. the oven shuts off on bake or broil at temperatures well below (100 degrees or more) what the erc display is showing. After awhile the F2 error code appears. I replaced the erc and checked the resistance on the oven temp sensor 1100ohms at room temperature and even hard wired the sensor by passing the plug by using wire nuts. No change. What else could it be?
  #2 (permalink)
Old 08-21-2008, 08:56 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Did you check the resistance at the erc of the oven sensor, 2 white wires? I that is ok, and the erc is ok, next thing to check would be the self cleaning latch switches for corrosion of wires etc. Start self clean and once the lock light quits flashing clear it, then check oven operation. If the switches are ok, look for a bad ground at the wall outlet. Another reason for f2 although rare is EMI interference. Ham radios, cordless phones, that sort of thing.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
f2 error code hotpoint range honeypot Oven Repair (including Ranges and Cooktops) 4 11-27-2008 08:02 AM
WP Range Error Code E2/F3 go2geye Oven Repair (including Ranges and Cooktops) 1 04-24-2008 11:05 PM
F3 Error on Frigidaire over the range microwave dignupfax Microwave Repair 2 01-29-2008 10:26 PM
Kenmore Range error code F2-E0 mtfurtney Oven Repair (including Ranges and Cooktops) 1 01-28-2008 11:27 AM
F3 Error code on whirlpool Range alex8469618 Oven Repair (including Ranges and Cooktops) 0 10-09-2007 03:18 PM
