| » Burner ignitors always on! |
Model Number: JDS8860BDP Brand: Jenn-Air Age: Less than 1 year
The burner ignitors are always firing. All control knobs are in the off position and no error codes are present on the display.
Related Models |
Try to access the panel with the burn controls and disconnect each ignitor switch (follow the wires from the switches to where they come together unplug one side and see if the clicking stops then the other side do the same thing. If they clicking stops the your switches are the problem if not it's your spark module. post your results. Nat |
| Display Modes | |
| stove top ignitors failing | jrmonson | Oven Repair (including Ranges and Cooktops) | 0 | 06-04-2008 08:05 AM |
| Ignitors won't click | hydrospirit | Oven Repair (including Ranges and Cooktops) | 5 | 02-04-2008 12:45 AM |
| Ignitors Won't Shutdown | rlawrence | Dishwasher Repair | 6 | 01-25-2008 04:29 PM |
| Viking cooktop ignitors supply? | slednerd | Oven Repair (including Ranges and Cooktops) | 1 | 01-22-2008 12:55 AM |
| burner gets hot. | raman | Oven Repair (including Ranges and Cooktops) | 1 | 11-27-2007 04:49 PM |
