Discuss
replacing cooktop with a smaller cooktop
 in
I am trying to replace an old 30yr GE electric cooktop with a Jenn-Air (used)...The opening is 30" X 21"....the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replacing cooktop with a smaller cooktop
  #1 (permalink)
Old 08-20-2008, 12:05 PM
Junior Member
oops is on a distinguished road
Default replacing cooktop with a smaller cooktop
Brand: Jenn-Air   Age: 1 - 5 years
I am trying to replace an old 30yr GE electric cooktop with a Jenn-Air (used)...The opening is 30" X 21"....the new cooktop's dimensions are 30" x 21.5". How can I compensate for the needed 1 or 2 inches to mount it? The counter is ceramic tile. Is there some type of gasket that is sold? The old one has a metal frame type thing around it....don't thing I can use it to hold the new one. Thanks.
Ads By Google
  #2 (permalink)
Old 08-20-2008, 12:21 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Your best bet would be to mount a 2x4 (or 1x4's one on each side) on one side of the opening and find some tile to cover it. It wouldn't take much tile to do that job and tile is easy to install. If you were close enough I'd give you the tile....lol....have a bunch I bought at an auction a few years ago.
nat
  #3 (permalink)
Old 08-20-2008, 12:36 PM
Junior Member
Default
Thanks for the quick response and the tile offer! Would I have to remove some tile to mount the 2x4 or do you think it could it be mounted from underneath the opening?
  #4 (permalink)
Old 08-20-2008, 12:43 PM
Senior Expert
APP Volunteer
Default
Yes mount it underneath the opening, then use a filler stip of wood to bring it up to level (if installing tile bring to level with allowance for appropriate tile/covering.
Nat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing GE Cooktop karska Oven Repair (including Ranges and Cooktops) 0 01-30-2010 01:17 PM
Replacing a Glass Cooktop mathomas Oven Repair (including Ranges and Cooktops) 0 01-09-2010 10:46 AM
help with replacing ceramic cooktop yofily Oven Repair (including Ranges and Cooktops) 0 07-06-2009 06:36 PM
Replacing Cooktop JNL Oven Repair (including Ranges and Cooktops) 0 08-25-2008 10:20 AM
replacing cooktop kenvan Oven Repair (including Ranges and Cooktops) 1 10-27-2007 02:47 PM
