| » Whirlpool Oven not heating fan runs continously |
Model Number: RBS3050DB8 Brand: Whirlpool Age: 5 - 10 years
My oven is a Whirlpool RBS305PDB8. The cooling fan runs continuously after power outage. I turned off the breaker to reset the oven and still have the same problem. As long as the power is switched on, the cooling fan is running. It will accept all the normal routine to start the oven such as the baking temp and the start button works but it skips the normal preheat routine. The temp will rise on the control panel as if everything is okay but the oven will be lukewarm and the burners never get red like before. The sensor and thermal fuse were tested and both were good. What could be the problem?
did you make sure you had 240volts at the outlet? I ask because you say the oven and your burners don't get hot like before, the electronic control does not control the surface burners, just want to try things before throwing maney at something that may not be the problem
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
I measured the volts in the outlet, it did have 240 volts. My oven is a wall oven. I did not say clear in my post, for the burners, I meant the burners in the oven, for broil and bake. Sorry about that and thanks for your time.
| Display Modes | |
| Whirlpool Gas Dryer Runs, Start Heating then gas heat goes off - stays off... | drs | Dryer Repair | 15 | 09-02-2008 02:44 PM |
| Ignitor Sparks Continously | Bikash | Oven Repair (including Ranges and Cooktops) | 0 | 04-13-2008 12:07 PM |
| Refrigerator runs continously | FRIG | Refrigerator & Freezer Repair | 3 | 10-31-2007 05:24 PM |
| Dryer wont stop cycle automatically runs continously | MrSchlimmer | Dryer Repair | 1 | 10-31-2007 04:43 AM |
| burner igniters fire continously | Mark65 | Oven Repair (including Ranges and Cooktops) | 0 | 10-08-2007 02:51 PM |
