Discuss
Kenmore Oven F0 Code
 in
I have a Kenmore wall oven Model No. 911.47822100. For some time the oven has been beeping and displaying
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Oven F0 Code
  #1 (permalink)
Old 08-19-2008, 04:10 PM
LostME LostME is offline
Junior Member
LostME is on a distinguished road
Default Kenmore Oven F0 Code
Model Number: 911.47822100   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore wall oven Model No. 911.47822100. For some time the oven has been beeping and displaying a F0 code. I was told by a service person, authorized Kenmore repair man, that I needed to replace the ERC. I ordered and replaced the ERC, but the oven is still displaying the same code. I was told by your customer service people that you might be able to help me determine if the ERC that I purchased is bad, or if there is the error is being caused by another part (I have a feeling it could be the key pad?).
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-20-2008, 06:59 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
It is most likey going to be the touch pad. Which will be the whole front control panel. Tom ApplianceEducator.com
  #3 (permalink)
Old 08-20-2008, 04:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
We can help you with the right part number for the control panel if you can post the color of it.
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 08-20-2008, 06:17 PM
Junior Member
Default
Gene and Tom, thanks for the replies.
The control panel is white. I believe that the part number is WB36T10444.
Is there any test I can perform to determine if the problem is with the control panel, and not the ERC, short of replacing the panel and seeing if that fixes the problem? These parts are fairly expensive.
Thanks again.
  #5 (permalink)
Old 08-21-2008, 06:05 AM
Senior Expert
APP Volunteer
Default
Basically we are also at the mercy of the manufacturer, we go to sheet, that tells us what the problem is, and that's that. 90% of the time, they are right. Tom ApplianceEducator.com
  #6 (permalink)
Old 08-22-2008, 05:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can do a simple test, but it does not 100% prove which part is bad.
Open the control panel and unplug the control panel ribbon from the control board (ERC). Restore the power and monitor the oven for one or two days. If the error code returns then the ERC is bad. If it would not, then the control panel is bad.
Also all GE (manufacturer of your oven) instructions referred this error code to a 50/50 chance to either of the control panel or ERC to be bad. You already replaced the ERC and now is the control panel turn.
__________________
  #7 (permalink)
Old 08-26-2008, 06:49 PM
Junior Member
Default
Well, I unplugged the ribbon, and it started beeping and showed the F0 code within five minutes. Unfortunately, it appears that I still don't know if it is the pad or the ERC - although it seems unlikely that I would get a bad ERC as a replacement for the original. Thanks.
  #8 (permalink)
Old 08-26-2008, 09:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by LostME View Post
...it seems unlikely that I would get a bad ERC as a replacement for the original...
Unfortunately defective new parts is not a surprise today but most likely the problem is a bad control panel.
The part number WB36T10444 you mentioned before is the correct part number for the control panel.
__________________
  #9 (permalink)
Old 08-28-2008, 03:33 PM
Junior Member
Default
I am going to go ahead and return the ERC and replace the control pad. Even if I end up replacing both parts - I'll still come out ahead of having someone repair it for me.
Thanks for all of your help.
  #10 (permalink)
Old 08-28-2008, 07:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You're welcome. Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore fault code 30 kim bielby Oven Repair (including Ranges and Cooktops) 0 07-15-2008 02:38 PM
Kenmore Oasis F1 Code Vacy72 Washer Repair 4 07-01-2008 09:56 AM
Kenmore F2 code imacbo Oven Repair (including Ranges and Cooktops) 0 05-07-2008 05:50 PM
Kenmore fault code F7 cris Oven Repair (including Ranges and Cooktops) 0 04-05-2008 05:46 AM
kenmore code not found briant Oven Repair (including Ranges and Cooktops) 3 11-26-2007 12:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
