Discuss
Reseat Ceramic Cooktop Panel to Cooktop
 in
Hello Forum, I have a ceramic (CERAN) cooktop panel that has become removed from the surrounding panel. It appears to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Reseat Ceramic Cooktop Panel to Cooktop
  #1 (permalink)
Old 08-18-2008, 09:16 PM
Twodoh Twodoh is offline
Junior Member
Twodoh is on a distinguished road
Question Reseat Ceramic Cooktop Panel to Cooktop
Model Number: BICT 600E - Fisher and Paykel   Brand: -other-   Age: 5 - 10 years
Hello Forum,
I have a ceramic (CERAN) cooktop panel that has become removed from the surrounding panel. It appears to heve been embedded in a "silicon" type compound which kept it anchored in place and also fitted it to the elements. I assume the "silicon" bead was also to assist with the swell shrink of the cooktop components whe the cooktop is in use.
Is it possible for me to refit (reseat) the ceramic panel, and if so how to I do it and what materials do I require?
Apart from the above the cooktop works very well.
I offer my thanks for any assistance you can provide to me.
Regards - Twodoh
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-19-2008, 05:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I do not think it is possible to fix it due to high temperature and special technology. It has to be replaced.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 08-23-2008, 06:53 PM
Junior Member
Default
Hello Gene,
thanks for your reply. I have talked with F and P (in Australia) and the replacement parts are disproportionally very expensive. I do accept that i will need to replace the cooktop and surround but is there any temporary solution that might tide me over for a few months? Regards - Terry
  #4 (permalink)
Old 08-23-2008, 07:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Terry,
Unfortunately I do not know anything you can use in such situation.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replace Ge ceramic cooktop blorb Oven Repair (including Ranges and Cooktops) 1 08-07-2008 10:29 AM
HELP - Replacing range ceramic glass cooktop Paul S Oven Repair (including Ranges and Cooktops) 0 02-28-2008 08:51 AM
ceramic cooktop burners not heating sadie26677 Oven Repair (including Ranges and Cooktops) 0 01-24-2008 10:25 AM
G.E. cooktop Jeff Miller Oven Repair (including Ranges and Cooktops) 1 10-19-2007 05:13 PM
Ceramic Cooktop slide-in oven/stove EVdelRsoario Oven Repair (including Ranges and Cooktops) 1 09-19-2007 01:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
