Discuss
Cannot set temperature on GE oven
 in
Mode buttons all work, can set broiler hi/low but when try to set temp in bake/roast only the &
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Cannot set temperature on GE oven
  #1 (permalink)
Old 08-16-2008, 09:07 AM
rabadir rabadir is offline
Junior Member
rabadir is on a distinguished road
Default Cannot set temperature on GE oven
Model Number: jpt18w0a1ww   Brand: GE   Age: 5 - 10 years
Mode buttons all work, can set broiler hi/low but when try to set temp in bake/roast only the "9" button has any effect and get message "BRD". If I press the start button then oven goes on in convection mode no matter the setting. Any thoughts?
Related Models
Jenn-Air JRC5 Ref - Single Door
Jenn-Air JRC5H Ref - Single Door
Jenn-Air JRC5HB Ref - Single Door
Jenn-Air JRC5HN Ref - Single Door
Jenn-Air JRC5N Ref - Single Door
General Electric JRP03*06 Electric range
General Electric JRP03*J1 Electric range
General Electric JRP03*J2 Electric range
General Electric JRP03*J3 Electric range
General Electric JRP03*J4 Electric range
General Electric JRP03*J5 Electric range
General Electric JRP03G*06 Electric range
General Electric JRP03G*07 Electric range
General Electric JRP03G*H1 Electric range
General Electric JRP03G*J1 Electric range
General Electric JRP03G*J2 Electric range
General Electric JRP03G*J3 Electric range
General Electric JRP03G*J4 Electric range
General Electric JRP03G*J5 Electric range
General Electric JRP14G*06 Electric range
General Electric JRP14G*H1 Electric range
General Electric JRP14G*J1 Electric range
General Electric JRP14G*J2 Electric range
General Electric JRP14G*J3 Electric range
General Electric JRP14G*J4 Electric range
General Electric JRP14G*J5 Electric range
General Electric JRP14G*J6 Electric range
General Electric JRP14GP1 Electric range
General Electric JRP14GP2BG Electric range
General Electric JRP14GP3BG Electric range
General Electric JRP14GP4BG Electric range
General Electric JRP14GT1BB Electric range
General Electric JRP14GV1BB Electric range
General Electric JRP15BW1BB Electric range
General Electric JRP15BW2BB Electric range
General Electric JRP15BW5BB Electric range
General Electric JRP15BW6BB Electric range
General Electric JRP15WP1 Electric range
General Electric JRP15WP2WG Electric range
General Electric JRP15WP3WG Electric range
General Electric JRP15WT1WW Electric range
General Electric JRP15WV1WW Electric range
General Electric JRP15WW1WW Electric range
General Electric JRP15WW2WW Electric range
General Electric JRP15WW5WW Electric range
General Electric JRP15WW6WW Electric range
General Electric JRP20BJ1BB Electric range
General Electric JRP20SK1SS Electric range
General Electric JRP20WJ1WW Electric range
General Electric JRP24BD1BB Electric range
General Electric JRP24BD2BB Electric range
General Electric JRP24BW1BB Electric range
General Electric JRP24BW2BB Electric range
General Electric JRP24BW5BB Electric range
General Electric JRP24GP1 Electric range
General Electric JRP24GP2BG Electric range
General Electric JRP24GP3BG Electric range
General Electric JRP24GP4BG Electric range
General Electric JRP24GT1BB Electric range
General Electric JRP24GV1BB Electric range
General Electric JRP28BJ1BB Electric range
General Electric JRP28SK1SS Electric range
General Electric JRS04BW1BB Electric range
General Electric JRS04BW2BB Electric range
General Electric JRS04BW3BB Electric range
General Electric JRS04BW4BB Electric range
General Electric JRS04BW5BB Electric range
General Electric JRS04BW6BB Electric range
General Electric JRS04GP1 Electric range
General Electric JRS04GP2BG Electric range
General Electric JRS04GT1BB Electric range
General Electric JRS04GV1BB Electric range
General Electric JRS06BJ1BB Electric range
General Electric JRS06SK1SS Electric range
Jenn-Air JRS1202W Ref - Sxs
Jenn-Air JRS202 Ref - Sxs
Jenn-Air JRS202B Ref - Sxs
Jenn-Air JRS202H Ref - Sxs
Jenn-Air JRS202L Ref - Sxs
Jenn-Air JRS202N Ref - Sxs
Jenn-Air JRS202W Ref - Sxs
Jenn-Air JRS203 Ref - Sxs
Jenn-Air JRS203B Ref - Sxs
Jenn-Air JRS203L Ref - Sxs
Jenn-Air JRS203N Ref - Sxs
Jenn-Air JRS203W Ref - Sxs
Jenn-Air JRS205L Ref - Sxs
Jenn-Air JRS205W Ref - Sxs
Jenn-Air JRS206A Ref - Sxs
Jenn-Air JRS206W Ref - Sxs
Jenn-Air JRS221 Ref - Sxs
Jenn-Air JRS221B Ref - Sxs
Jenn-Air JRS221L Ref - Sxs
Jenn-Air JRS221N Ref - Sxs
Jenn-Air JRS221W Ref - Sxs
Jenn-Air JRS223 Ref - Sxs
  #2 (permalink)
Old 08-16-2008, 09:14 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
This is most likely your problem... Part Details - GE Panel control a, part number: WB36T10196
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-16-2008, 09:20 AM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
It could also be part #AP2633043, the main control board
Nat
  #4 (permalink)
Old 08-16-2008, 09:33 AM
Junior Member
Default
Any way to tell if it is the control panel or the front panel that is really the problem?
  #5 (permalink)
Old 08-16-2008, 09:42 AM
Senior Expert
APP Volunteer
Default
does it beep when you push the buttons?
  #6 (permalink)
Old 08-16-2008, 09:52 AM
Junior Member
Default
Beeps with all buttons except 1-8
  #7 (permalink)
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
You can take a continuity check of the ribbon cable. Take off the control panel, open the door and locate the 3 screws under the panel. Take them out and push up on the panel to unlock it and it will come right out. Make sure you have turned the power off. Now locate the service manual taped to the left side and there are instructions in there on how to perform a continuity check of the ribbon cable.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Incorrect oven temperature cwren Oven Repair (including Ranges and Cooktops) 2 06-06-2008 01:41 PM
GE Oven temperature fivermillions Oven Repair (including Ranges and Cooktops) 1 12-25-2007 01:57 PM
Oven Temperature Runaway jimk Oven Repair (including Ranges and Cooktops) 1 12-09-2007 01:27 PM
oven temperature rodrbrown Oven Repair (including Ranges and Cooktops) 0 12-08-2007 01:52 PM
oven temperature rodrbrown Oven Repair (including Ranges and Cooktops) 0 12-08-2007 01:47 PM
