Discuss
Whirlpool fault code E6 F2
 in
According to Whirlpool tech sheets (definitely not the best one) I would replace the control panel first, but there is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool fault code E6 F2
  #31 (permalink)
Old 05-06-2009, 08:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
According to Whirlpool tech sheets (definitely not the best one) I would replace the control panel first, but there is a chance for the control board to be bad as well.
- The part number for the control panel is AP3131916
- The part number for the control board is AP3767567
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBD275PDB12 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #32 (permalink)
Old 05-09-2009, 12:46 PM
Junior Member
chrishaskins is on a distinguished road
Default Actually replacing the control board and control panel
Whirlpool RBD305PDQ8 White double oven
Hi, I bought a new control board and panel. I am wondering if there is anything more than pulling the connectors off the old board and conecting them to the new one in order to replace it. I will be very careful attaching the ribbon from the control panel to the board as I read earlier posts. Is there any particular start-up sequence once the board and panel are replaced and the power turned back on? I once read about pressing a certain sequence of buttons to start it up correctly.
Thanks,
Chris
  #33 (permalink)
Old 05-10-2009, 02:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Chris,
You probably have to program the cavity size when replacing the control board. The procedure should be described in the tech sheets inside the control panel. "Cavity size" means width of the oven. It can be 24", 27" or 30".
__________________
  #34 (permalink)
Old 07-17-2009, 03:44 PM
Junior Member
Pete79 is on a distinguished road
Default
Gene, been reading along and I HAD a E6 F2 code, replaced the control board and all seemed great.. Till I tried the upper and lower ovens. Once I push the 'start' button I get an E1 F2 code now..
The oven is a Whirlpool gold double convection Model # GBD307PDS09
Any help is appreciated...
Pete
  #35 (permalink)
Old 07-17-2009, 03:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Pete,
The "F2-E1" error code means:"Keypad keytail not connected".
Remove the ribbon cable from the control board and check the tracks in the ribbon cable for hairline cracks using a magnifying glass. Clean the ribbon cable connector with a pencil eraser. Reconnect everything and give it a try. If it would not help then the control panel assembly has to be replaced.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GBD307PDS09 | AppliancePartsPros.com
__________________
  #36 (permalink)
Old 07-17-2009, 04:13 PM
Junior Member
Default
Thanks for the quick reply Gene, Everything looks good on it, no fine cracks or folds, but clearly there must be an issue with it.
I'll be ordering the new panel today...
Pete
  #37 (permalink)
Old 08-01-2009, 11:03 AM
Junior Member
Default
That was the problem Gene - replaced the part and oven works perfect!
Thanks again!
  #38 (permalink)
Old 08-01-2009, 04:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Pete. I'm glad you were able to fix it.
__________________
  #39 (permalink)
Old 08-05-2009, 06:48 PM
Junior Member
barglancy is on a distinguished road
Default
I purchased a new board and panel to fix the e6 f2 code. On the board 2 black connectors on the left hand side need to be disconnected from the old board. My part number is AP3767567.
Do I just yank them out or is there a trick? Don't want to do any damage to the connectors
  #40 (permalink)
Old 08-05-2009, 07:25 PM
Junior Member
Default
I yanked them and the oven appears to be working with the new parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html
Posted By For Type Date
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 09-07-2009 04:15 PM
Whirlpool Parts and Whirlpool Repair Help from AppliancePartsPros.com This thread Refback 07-19-2009 06:48 AM
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 06-07-2009 01:43 PM
Similar Threads
Whirlpool fault code E6 F2 msdabbert Oven Repair (including Ranges and Cooktops) 1 10-20-2011 12:35 PM
Whirlpool fault code E6 F2 pcbulins Oven Repair (including Ranges and Cooktops) 0 11-19-2009 07:44 PM
whirlpool f7 fault code copper Microwave Repair 0 08-15-2009 10:46 AM
Whirlpool Fault code F2 mrbruce300 Washer Repair 1 07-15-2009 01:58 PM
Whirlpool Fault code E2 F3 t6865mc Oven Repair (including Ranges and Cooktops) 1 02-27-2009 05:57 AM
