Discuss
Whirlpool fault code E6 F2
 in
Scott, I've read the other post first and the answer is there: http://forum.appliancepartspros.com/...html#post59221 Gene. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool fault code E6 F2
  #21 (permalink)
Old 01-26-2009, 10:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Scott,
I've read the other post first and the answer is there: Whirlpool Double Oven Dead
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #22 (permalink)
Old 02-25-2009, 09:21 AM
Junior Member
FloMoRon is on a distinguished road
Default Replaced control board - new problem
Gene, I followed your advice and replaced the control board on my double oven. Within 2 months, the convection button and the "temperature higher" button stopped working. Do you think it is a defect in the control board or do I need to replace the panel, maybe because those buttons aren't triggering the commands? Thanks.
  #23 (permalink)
Old 02-25-2009, 02:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
FloMoRon,
What is the complete model number of the oven?
__________________
  #24 (permalink)
Old 02-26-2009, 06:08 AM
Junior Member
Default
The Whirlpool Gold double oven with convection, black and stainless, is
GBD307PDS09. I purchased the control board through this website on 10/8/08.
Thanks.
  #25 (permalink)
Old 02-26-2009, 05:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel and check the ribbon, using a magnifier. Most likely the problem is a bad control panel.
__________________
  #26 (permalink)
Old 02-27-2009, 07:23 AM
Junior Member
Default
I did have a hard time getting the ribbon back in. I wonder if I broke it somehow. I will check it with a magnifier. Thanks again for all your help. I appreciate it.
  #27 (permalink)
Old 02-27-2009, 11:56 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #28 (permalink)
Old 05-05-2009, 06:56 PM
Junior Member
caryn is on a distinguished road
Default Help!!!
Gene:
Ive been reading your advice and it seems like you are the end all, know all of this type of stuff. I was wondering if you had any input. We have a double wall over RBD275PDB12, black. LIke the other users, we have the error message E6 F2 but it only comes on randomly. Oven does not work. We cant figure out how to unplug the over from the wall. Its a metal pipe-looking thing that may be a casing? Not sure. But I looked at the control panel and the three little skinny white barrells on the back near the red and blue wires are FIRE HOT! The red and blue wires have continuity from the transformer.
Do you know where the plug is on this oven and what may be causing our problem?
Thanking you so much in advance.
  #29 (permalink)
Old 05-06-2009, 07:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This oven does not have a plug. It is hardwired. Why do you need to unplug it? In order to turn the power "off" just turn "off" the oven double breaker. If you need to remove the oven from the cabinet then the cable should be long enough to let you do it.
You said this is a double oven. Which oven does not work? It does not not work completely or just one function? What you said about the control board looks to me as normal.
Can you describe the problem (s) more specifically?
__________________
  #30 (permalink)
Old 05-06-2009, 07:57 PM
Junior Member
Default
Gene, sorry I was not more specific. Neither of the ovens work. The E6 F2 code comes on, once in a while. Otherwise, its a blank screen. If you open either of the over doors (upper or lower), the light will come on. But pushing any of the buttons on the panel doesnt do anything. I am guessing from reading your site that its either the control panel or board? When I removed the control panel (so that the green board is exposed), the E6 F2 came back on. We havent seen that code (or any activity) in weeks. Its as if something we did by removing the front panel helped it.
Any help you could give would be great!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html
Posted By For Type Date
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 09-07-2009 04:15 PM
Whirlpool Parts and Whirlpool Repair Help from AppliancePartsPros.com This thread Refback 07-19-2009 06:48 AM
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 06-07-2009 01:43 PM
Similar Threads
Whirlpool fault code E6 F2 msdabbert Oven Repair (including Ranges and Cooktops) 1 10-20-2011 12:35 PM
Whirlpool fault code E6 F2 pcbulins Oven Repair (including Ranges and Cooktops) 0 11-19-2009 07:44 PM
whirlpool f7 fault code copper Microwave Repair 0 08-15-2009 10:46 AM
Whirlpool Fault code F2 mrbruce300 Washer Repair 1 07-15-2009 01:58 PM
Whirlpool Fault code E2 F3 t6865mc Oven Repair (including Ranges and Cooktops) 1 02-27-2009 05:57 AM
