Discuss
Whirlpool fault code E6 F2
 in
hello .. joining the helping hand on all things appliances .. it would be great to get expert advices in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool fault code E6 F2
  #271 (permalink)
Old 01-06-2014, 01:42 AM
Junior Member
MikeWolfes is on a distinguished road
Default
hello .. joining the helping hand on all things appliances .. it would be great to get expert advices in turn of seeking any fix against any damages
  #272 (permalink)
Old 01-22-2014, 03:02 AM
Junior Member
Default
is there any pics of the process to get it better ? possibly posting them would help me much along with others as well
  #273 (permalink)
Old 09-26-2014, 02:38 PM
Junior Member
esypes is on a distinguished road
Default
Hi Gene,
I had this error and sent the control board to Corecentric for repair. I had it back in 2 days. When I hooked it up two of my control panel buttons were not working. The ribbon cable looked pretty beat up so I ordered a control panel from this web site and had it overnighted. Same thing only different buttons now. Some work and some don't. The right side lower oven off does not work and the left side upper and lower oven buttons along with convection do not work.
Any ideas before I just go new oven shopping tomorrow?
I had the board repaired and also bought part # AP3043893 (8300440)
My oven is part # GBD307PDB7
Thanks,
Eric
  #274 (permalink)
Old 09-29-2014, 09:14 PM
Junior Member
Carolinian is on a distinguished road
Default Need your help !!!
Hello,
I have a 7 yr old Whirlpool double oven, GBD307PRY01, that stopped working around 6 months back. It start with an E6 F2 code initially and would work sporadically. Then recently, display is dead, oven lights work and keypad buttons beep. Oven does not turn on.
So, I opened it up and gently cleaned the ribbon with IPA and reconnected it back and still dead (lights work, buttons beep). Also checked the fuse with a multimeter and it checks out fine. From reading the messages in this thread, seems like it is a control board issue. Is that right?
Also, how do I disconnect the wires on the relay (there are 4 black connectors on the left side with wires that are impossible to yank off) of the control board. Here is a pic of the area in question (you can see the 2 relays on the left and right and the wires to the bottom harness and the one behind it).
https://drive.google.com/file/d/0B76...it?usp=sharing
Can someone please let me know how to get these wires off so I can try replacing the control board?
Thanks a bunch!
  #275 (permalink)
Old 09-30-2014, 10:33 AM
Junior Member
Default
Just answering my own question. It was pretty hard to yank off the wires from the relay but all it needed was a good hard tug. As for the other 2 harnesses, that also would not pull out easily, I had to push it up by placing a screwdriver under the black connector and then pull it out. Those were really hard to figure out for me. Hope this helps someone
  #276 (permalink)
Old 10-29-2014, 06:14 AM
Junior Member
Smile Fixed Finally!!!
A final update on my journey to fix the oven. I also tested the fuse with a multimeter and the resistance was fine (so that was not the problem). Ordered the control board assembly (board + black plastic cover) from Appliance Parts Pros, for about $260 and replaced it in the oven. After plugging in the connectors, I turned on the switch at the circuit breaker and then switched on the oven, it worked like a charm. Also tested it for a month to see how it performs and we are back to normal now.
I had asked good repair places and they quoted over $500 to fix it. APP shipped quickly and delivered the board in a couple of days and I was very pleased with them. Thank you, APP
  #277 (permalink)
Old 11-26-2015, 11:24 AM
Junior Member
Kafansler is on a distinguished road
Default Help needed with E6 F2 code
I have a Whirlpool double wall oven with intermittent error code E6 F2. Sometimes the ovens work and then sometimes they won't. After reading the above posts I think it is probably a control board going out. I have looked and can't find a control board that is still in production. Can anyone help? Model number is RBD305PDB12 ser # CPO403303.
Kyle
  #278 (permalink)
Old 06-30-2016, 06:11 PM
Junior Member
malimalek@yahoo.com is on a distinguished road
Question Whirlpool Oven IBS550P
Hi
Yesterday we used self-clean cycle of oven. The temperature was very high, so after few hours the door of oven locked. we wait to be cool but it doesn't open till now! the display doesn't show anything. We pull out oven from the cabinet and opened the back of oven. my question is how can I bypass the fuze? and remove the fuze? Actually I don't know what happened after self-clean! Would you please help me.
F.Riahi
  #279 (permalink)
Old 10-12-2017, 01:40 PM
Junior Member
gregdavis11009 is on a distinguished road
Thumbs up Part discontinued but Sears still has it.
I had to go onto the chat window but the Sears agent was able to find the part for the control panel (the black one) base on my oven model number (GBD277PDS09). $212.34 including shipping & tax. Good luck!
Last edited by gregdavis11009 : 10-12-2017 at 01:43 PM. Reason: added model number
  #280 (permalink)
Old 10-12-2017, 01:56 PM
Junior Member
Default
Hey Kafansler,
Try this link for your model (RBD305PDB12):
"https://www.fix.com/models/wall-oven/whirlpool/id236672/rbd305pdb12/section760684/control-panel/"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html
Posted By For Type Date
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 09-07-2009 05:15 PM
Whirlpool Parts and Whirlpool Repair Help from AppliancePartsPros.com This thread Refback 07-19-2009 07:48 AM
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 06-07-2009 02:43 PM
Similar Threads
Whirlpool fault code E6 F2 msdabbert Oven Repair (including Ranges and Cooktops) 1 10-20-2011 01:35 PM
Whirlpool fault code E6 F2 pcbulins Oven Repair (including Ranges and Cooktops) 0 11-19-2009 08:44 PM
whirlpool f7 fault code copper Microwave Repair 0 08-15-2009 11:46 AM
Whirlpool Fault code F2 mrbruce300 Washer Repair 1 07-15-2009 02:58 PM
Whirlpool Fault code E2 F3 t6865mc Oven Repair (including Ranges and Cooktops) 1 02-27-2009 06:57 AM
