| » Whirlpool fault code E6 F2 |
You are welcome.
You may want to verify if the oven is set to read the temperature in Fahrenheit and not in Celsius. It is possible you did it accidentally while trying to adjust the oven cavity size. The Owners manual will help you to find out the proper adjustments. Gene. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hello Gene
In regards my oven Model Number GBD307PDS09, Serial # XR3400838, color Stainless steel with Black trim, I have posted before about error code F2 E6. Generally I am able to press some buttons, it clears and I go back to using the oven. Took your advice about the eraser to the ribbon on the control Panel around Dec. 2012. My oven has been working perfectly since. Until today. The display is completley blank, no error code. The buttons beep when pressed but the oven will not come on, I flipped the breaker and still no dice. Probably time to throw in the towel and replace the Control Panel and/or Control Board. Just thought I would check in for your well respected advice. Thanks |
Hello,
Open the control panel and check the low voltage transformer for continuity. The normal readings suppose to be: primary winding P16-5 (Red) to P16-7 (Red) - 75Ω to 95Ω; secondary winding P16-2 (Blue) to P16-3 (Blue) - < 1Ω. If the readings are incorrect, replace the transformer. If the readings are correct, replace the control board. - The low voltage transformer Part number: 9760587 - The control board Part number: W10406070 Gene.
__________________
| Display Modes | |
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html
| Posted By | For | Type | Date | |
| Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa | This thread | Refback | 09-07-2009 04:15 PM | |
| Whirlpool Parts and Whirlpool Repair Help from AppliancePartsPros.com | This thread | Refback | 07-19-2009 06:48 AM | |
| Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa | This thread | Refback | 06-07-2009 01:43 PM | |
| Whirlpool fault code E6 F2 | msdabbert | Oven Repair (including Ranges and Cooktops) | 1 | 10-20-2011 12:35 PM |
| Whirlpool fault code E6 F2 | pcbulins | Oven Repair (including Ranges and Cooktops) | 0 | 11-19-2009 07:44 PM |
| whirlpool f7 fault code | copper | Microwave Repair | 0 | 08-15-2009 10:46 AM |
| Whirlpool Fault code F2 | mrbruce300 | Washer Repair | 1 | 07-15-2009 01:58 PM |
| Whirlpool Fault code E2 F3 | t6865mc | Oven Repair (including Ranges and Cooktops) | 1 | 02-27-2009 05:57 AM |
