| » Whirlpool fault code E6 F2 |
Quote:
Hi Bob, Where did you find the instructions for removing the screws on the side of the oven door? The following are instructions posted for smitty33 on the first page of this thread. Quote:
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
So Ed,
Did Shawn actually have to replace the control panel only to realize he needed to replace the control board? Could the issue only have been the control baord? I would hate to spend the $170 and then the $380, respectively, for the two components when only one (the control panel) mave have been the cultprit. |
Similar Whirlpool Gold double oven, top convection Model # GBD307PDS7 serial # XP3204933
Both ovens working perfectly top convectioning at 350, bottom baking at 380. Food was finished, turned both off and whole oven went dead. Has power to oven and measures 120V on both hots and 120V at control board inputs. Have old control board from same oven, previous repair top oven would not cause cooling fan to run. Put in that board and all is still dead which makes me think it is something else hopefully??? Where to look next? thank you!!!! |
There suppose to be a control panel thermal fuse wired into the black (hot) input wire into the control board. Find it and check it for continuity.
__________________
You are welcome. If you need the part number for this fuse post a picture of it.
__________________
Gene, I'm hoping you can help me understand something:
Quote:
Quote:
I'm not at all a DIY type, so I had a repairman come out to take a look. He said he would try each one, and only charge me for the parts he ended up using. Alternatively, I can buy the board off ******** for $100 less... but I can't return it if I end up not needing it. So I'm trying to decide whether to buy a board. My display used to show E6 F2, but it's been blank... for about two years Thanks for your awesome help! |
| Display Modes | |
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html
| Posted By | For | Type | Date | |
| Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa | This thread | Refback | 09-07-2009 04:15 PM | |
| Whirlpool Parts and Whirlpool Repair Help from AppliancePartsPros.com | This thread | Refback | 07-19-2009 06:48 AM | |
| Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa | This thread | Refback | 06-07-2009 01:43 PM | |
| Whirlpool fault code E6 F2 | msdabbert | Oven Repair (including Ranges and Cooktops) | 1 | 10-20-2011 12:35 PM |
| Whirlpool fault code E6 F2 | pcbulins | Oven Repair (including Ranges and Cooktops) | 0 | 11-19-2009 07:44 PM |
| whirlpool f7 fault code | copper | Microwave Repair | 0 | 08-15-2009 10:46 AM |
| Whirlpool Fault code F2 | mrbruce300 | Washer Repair | 1 | 07-15-2009 01:58 PM |
| Whirlpool Fault code E2 F3 | t6865mc | Oven Repair (including Ranges and Cooktops) | 1 | 02-27-2009 05:57 AM |
