Discuss
Whirlpool fault code E6 F2
 in
What is the part number of the control board you are looking for? Gene.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool fault code E6 F2
  #181 (permalink)
Old 02-08-2012, 03:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #182 (permalink)
Old 03-06-2012, 03:02 PM
Junior Member
YoungPadawan is on a distinguished road
Default
E6F2 error codes generally mean the control board is on the way out, especially if you're seeing a blank screen. Replacing the keypad or cleaning the ribbon is only delaying the inevitable. But you don't have to buy a new controller (especially since many of them are no longer available). Running a google search for ************************ should lead you to a company that can repair oven controllers.
  #183 (permalink)
Old 03-08-2012, 09:18 AM
Junior Member
kodiak23 is on a distinguished road
Default Board Discontinued?
Hi Gene -
I am looking to order AP3767567 for my RBD275PDQ8, but I was told it is discontinued. Can you confirm or help me find one? I'd rather get a new one then track down an old one.
Cody
  #184 (permalink)
Old 03-08-2012, 05:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Cody,
I did search for this part and I found that it is still available but it's on a back order. You have to talk to the APP team to find ETA.
__________________
  #185 (permalink)
Old 03-08-2012, 06:07 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Cody,
Thanks Gene. I talked to them a couple days ago and they said it was discontinued. Any other ideas on how I could get a board, so I can fix my oven? Or do I need to buy an entirely new oven? Thanks for your help.
  #186 (permalink)
Old 03-16-2012, 09:42 AM
Junior Member
machong is on a distinguished road
Default
Hello Gene,
I have Whirlpool Model # GBD307PRQ01 Similar situation that others have posted. Display goes out mid-bake cycle. Oven heat and light still work. Display comes back slowly. Today error code E6 F2 came on. What steps should I take to determine issue. I have read the thread but want to make sure I do things in the right order.
Thanks for all of your help.
Marcie
  #187 (permalink)
Old 03-16-2012, 01:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello Marcie,
Very likely the problem is a bad control board. Especially because of the display which goes on & off.
- The control board Part number: AP4909214
You can call the APP customer service to find the part ETA.
Here are the breakdown diagrams and Replacement parts for Whirlpool GBD307PRQ01 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION-UPPER SELF-CLEAN (GOLD LINE) | AppliancePartsPros.com
__________________
  #188 (permalink)
Old 03-17-2012, 05:41 AM
Junior Member
Default
Hello Marcie,
Is there a way or something to check that might be loose?
  #189 (permalink)
Old 03-17-2012, 04:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Unfortunately there are no such parts. I understand you point. This part is very expensive, but this is the only way to fix it.
__________________
  #190 (permalink)
Old 03-31-2012, 09:55 AM
Junior Member
Aimin is on a distinguished road
Default
Hi Gene,
I have posted this a couple of days ago but maybe you can provide some insight as I have been following you with the repair.
My double oven stop working a month ago. After I have changed thermal fuse and control panel, it worked, for one night! The next morning, it stopped working again. I checked to find out the fuse is out and I remembered that the R90-92 to be hot. So I order a control board and new thermal fuse. I put them back tonight and it worked! However I found that the parts R90-92 were pretty hot, and I am afraid that something else is wrong besides the board. Should these parts be hot? Is there a way to check? Would I not doing the program cavity size cause the problem? Thanks in advance!
Aimin
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html
Posted By For Type Date
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 09-07-2009 04:15 PM
Whirlpool Parts and Whirlpool Repair Help from AppliancePartsPros.com This thread Refback 07-19-2009 06:48 AM
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 - FixYa This thread Refback 06-07-2009 01:43 PM
Similar Threads
Whirlpool fault code E6 F2 msdabbert Oven Repair (including Ranges and Cooktops) 1 10-20-2011 12:35 PM
Whirlpool fault code E6 F2 pcbulins Oven Repair (including Ranges and Cooktops) 0 11-19-2009 07:44 PM
whirlpool f7 fault code copper Microwave Repair 0 08-15-2009 10:46 AM
Whirlpool Fault code F2 mrbruce300 Washer Repair 1 07-15-2009 01:58 PM
Whirlpool Fault code E2 F3 t6865mc Oven Repair (including Ranges and Cooktops) 1 02-27-2009 05:57 AM
