thecarrollteam
#1 Posted : Thursday, August 14, 2008 3:37:38 PM(UTC)
thecarrollteam
We just replaced the safety valve, manufactuers part number of 3195008. We have replaced all gas lines to the proper places and used teflon tape on all threads for snug fits. When we turn the oven on to preheat the, what we believe to be the ignitor, is glowing and red hot, but the gas doesn't seem to make it into the tube running from the ignitor to the front of the oven. We are on LP gas. Is there a pilot light that needs to be re-lit? If so, where? Thank you!!!! Please help, we have been without an oven for about a month and thank goodness it is summer....... :)
libertyappl
#2 Posted : Friday, August 15, 2008 10:45:06 AM(UTC)
libertyappl
Sounds like your ignitor may need to be replaced. If you have an ohm meter, unplug it and test for continuity. If none replace the ignitor.
thecarrollteam
#3 Posted : Tuesday, August 19, 2008 5:47:35 AM(UTC)
thecarrollteam
It is the ignigtor that is also bad. Thank you so much for your quick and educated response. Best wishes to your Mom and Pop operation!!!:) :)
libertyappl
#4 Posted : Tuesday, August 19, 2008 6:16:23 AM(UTC)
libertyappl
One other tid bit.....the LP companys around here do not recommend teflon tape for gas fittings. We a putty type stuff for gas lines. Just make sure your connections are good and tight with no leaks.
Nat
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Whirlpool oven WFE505W0HB2 (Oven Repair (including Ranges and Cooktops))
by Guest 1/7/2023 5:44:02 AM(UTC)
Whirlpool oven broil element doesn't go off and code F3 E2 (Oven Repair (including Ranges and Cooktops))
by Right_to_Repair 3/29/2022 1:54:22 PM(UTC)
Whirlpool oven approximately (2006) (Oven Repair (including Ranges and Cooktops))
by Guest 2/28/2022 3:02:09 PM(UTC)
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Kitchen Aid/whirlpool oven does not light on the first try (Oven Repair (including Ranges and Cooktops))
by Deintinis 11/22/2020 7:42:29 AM(UTC)
Whirlpool oven won’t stay lit (Oven Repair (including Ranges and Cooktops))
by jc0786 11/15/2020 7:11:47 AM(UTC)
Whirlpool Oven - RBS307PVS03 - Fuse for front control (Oven Repair (including Ranges and Cooktops))
by lmagdaleno 11/8/2020 11:50:57 AM(UTC)
Whirlpool oven & broiler wont start (Oven Repair (including Ranges and Cooktops))
by rstonina 5/13/2019 12:35:09 PM(UTC)
