Unit was working fine, then we had an Ice Storm in Feb I still had power but the lines were on the ground. I left on business . I believe the cut power in May. When I returned the first of this month and had the Power restored the Oven contol was blank but the rest of the Unit works. What if anything, Beside replacing the control unit, can be done
Originally Posted by: gas6970 Unit was working fine, then we had an Ice Storm in Feb I still had power but the lines were on the ground. I left on business . I believe the cut power in May. When I returned the first of this month and had the Power restored the Oven contol was blank but the rest of the Unit works. What if anything, Beside replacing the control unit, can be done With everything else working, top burners, oven elements ? You most likely have, a damaged display circuit in your range control and will need to repalce it, or a burnt wire at the control and will need to repair it, but the oven elements should not work if that were the case. in either case , burnt wire or damaged control, you'll have it taken care of easily.
