One of the burners in my cooktop stop functioning. If you use 3 of the 4 knobs, it will start the ignitor for the appropriate 3 burners, It will also run the ignitor for the forth (bad) burner.
I can use the bad burner by igniting of the 3 and supplying gas to the forth burner. The 4th burner when I put it in the ignition position does not click at all. But the other 3 burners when activating them also activates the bad burner.
This is a new problem, it has been functioning for over 3 years with no changes. Any ideas? What should I look at. Thanks
Alex
It is definatly your ignitor switch harness that needs replacing. If you get me the whole model# I can provide you the part# needed.
I have the same problem, and the model number is JGSP33WEV1WW.
Could you please help me find the part.
Thanks for the tips
Lann
