Discuss
Control Board or Control Panel?
 in
I have researched this forum and others for problems with the Whirlpool oven display panels, but am not sure whether
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Control Board or Control Panel?
  #1 (permalink)
Old 07-22-2010, 06:01 PM
Junior Member
bbq.phil is on a distinguished road
Default Control Board or Control Panel?
Model Number: RBD305PDB12   Brand: Whirlpool   Age: 5 - 10 years
I have researched this forum and others for problems with the Whirlpool oven display panels, but am not sure whether I should be focusing on replacing the control panel or the control board.
Over the past year or longer, when in use, the oven would occasionally beep once and just stop working, possibly displaying a PF error message. In addition, at times the display looked "weak". We would wait a little while, then reset the clock and all was well until the next time this happened.
Although I cannot say for sure, we began to get a feeling that the situation - which by no means happened every time we used the oven - was heat related. As a result, at times we would actually use the bottom oven, thinking it further away from the electronics at the top. Indeed, the occurrence did seem to happen more often from heavier use, such as during a holiday.
Three days ago, the oven, while not being used, emitted a beep code of long-short-short-short and the display went completely blank. Pressing on a button emits a normal beep, but pressing the "Start" button emits the normal beep, then a sequence of long-short-short-short. Turning off the breaker for a period of time and back on does not resolve the issue - still a blank display. Note that the "Light" button does indeed work, illuminating the lights in the oven.
Researching this site led me to one of three possible solutions: Control Panel, Control Board, or Transformer.
Looking for the least expensive possible solution, I purchased a replacement transformer from AppliancePartsPros.com ($18) and replaced it. Upon restoring power, the display came to life, and displayed the "E6 F2" error code one time. After that, I was able to set the clock. However, some 15 or 20 minutes later, the beep sequence occurred again and now the display is blank again. Note that I was very conscientious regarding reconnection of the ribbon cable from the panel to the board connector.
SO...after replacing the transformer, and having only witnessed the "E6 F2" error once (but having consistently heard and ability to replicate the long-short-short-short beep code), I am wondering if there is a clear direction to take next in terms of replacing the control panel or the control board. The panel is about $145 and the board is $210, so I would prefer to get this right the first time rather than buy both (unless they're both shot and I have no choice!)
Thank you for any advice you may have...any way this happens, your site, advice, and parts will end up saving me big $$.
Ads By Google
Related Models
Whirlpool RBD305PDB12 ELECTRIC OVEN
Whirlpool RBD305PDB13 ELECTRIC OVEN
Whirlpool RBD305PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB2 ELECTRIC OVEN
Whirlpool RBD305PDB3 ELECTRIC OVEN
Whirlpool RBD305PDB4 ELECTRIC OVEN
Whirlpool RBD305PDB6 ELECTRIC OVEN
Whirlpool RBD305PDB7 ELECTRIC OVEN
Whirlpool RBD305PDB8 ELECTRIC OVEN
Whirlpool RBD305PDB9 ELECTRIC OVEN
Whirlpool RBD305PDQ1 ELECTRIC OVEN
Whirlpool RBD305PDQ10 ELECTRIC OVEN
Whirlpool RBD305PDQ11 ELECTRIC OVEN
Whirlpool RBD305PDQ12 ELECTRIC OVEN
Whirlpool RBD305PDQ13 ELECTRIC OVEN
Whirlpool RBD305PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ2 ELECTRIC OVEN
Whirlpool RBD305PDQ3 ELECTRIC OVEN
Whirlpool RBD305PDQ4 ELECTRIC OVEN
Whirlpool RBD305PDQ6 ELECTRIC OVEN
Whirlpool RBD305PDQ7 ELECTRIC OVEN
Whirlpool RBD305PDQ8 ELECTRIC OVEN
Whirlpool RBD305PDQ9 ELECTRIC OVEN
Whirlpool RBD305PDS12 ELECTRIC OVEN
Whirlpool RBD305PDS14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDS15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT11 ELECTRIC OVEN
Whirlpool RBD305PDT12 ELECTRIC OVEN
Whirlpool RBD305PDT13 ELECTRIC OVEN
Whirlpool RBD305PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB1 Built-In Oven, Electric
Whirlpool RBD306PDB10 OVEN
Whirlpool RBD306PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB12 OVEN
Whirlpool RBD306PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB2 Built-In Oven, Electric
Whirlpool RBD306PDB4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDB8 ELECTRIC WALL OVEN
Whirlpool RBD306PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ1 Built-In Oven, Electric
Whirlpool RBD306PDQ10 OVEN
Whirlpool RBD306PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ12 OVEN
Whirlpool RBD306PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ2 Built-In Oven, Electric
Whirlpool RBD306PDQ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT12 OVEN
Whirlpool RBD306PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDZ1 30" BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ10 OVEN
Whirlpool RBD306PDZ2 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDZ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD307PDB1 ELECTRIC OVEN
Whirlpool RBD307PDB2 ELECTRIC OVEN
Whirlpool RBD307PDQ1 ELECTRIC OVEN
Whirlpool RBD307PDQ2 ELECTRIC OVEN
Whirlpool RBD307PDQ4 ELECTRIC OVEN
Whirlpool RBD307PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVS03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Maytag RBE170PA REF - TOP MOUNT
Maytag RBE170PW REF - TOP MOUNT
Maytag RBE170TA REF - TOP MOUNT
Maytag RBE170TM REF - TOP MOUNT
Maytag RBE170TV REF - TOP MOUNT
Maytag RBE170TW REF - TOP MOUNT
Maytag RBE17KA-0A REF - TOP MOUNT
Maytag RBE17KN-0A REF - TOP MOUNT
Maytag RBE193PA REF - TOP MOUNT
Maytag RBE193PW REF - TOP MOUNT
Maytag RBE193TA REF - TOP MOUNT
Maytag RBE193TM REF - TOP MOUNT
Maytag RBE193TV REF - TOP MOUNT
Maytag RBE193TW REF - TOP MOUNT
Maytag RBE19KA-3A REF - TOP MOUNT
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
control panel or board???? junebugtraveler Dishwasher Repair 7 02-05-2011 02:22 AM
Kenmore Built In Oven Control Panel And Oven Control Board. TDEUCEDOG06 Oven Repair (including Ranges and Cooktops) 0 06-01-2010 03:28 PM
Control Panel or Board problem axis Dishwasher Repair 0 05-11-2010 08:02 PM
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 12:09 PM
Control Panel/Circuit Board S.Lynch55 Washer Repair 0 04-05-2009 02:44 PM
