Discuss
Wall oven hit by voltage surge
 in
After a high voltage surge, the oven is DOA. My questions are: 1) Can the oven be resurrected? 2) What
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wall oven hit by voltage surge
  #1 (permalink)
Old 07-22-2010, 11:04 AM
Junior Member
adons is on a distinguished road
Default Wall oven hit by voltage surge
Model Number: JGW8130DDB   Brand: Jenn-Air   Age: 5 - 10 years
2) What parts are probably required?
Many thanks
Ads By Google
Related Models
Jenn-Air JGW8130DDB Walloven - S/c Gas
Whirlpool JGW8130DDB12 30" Built - in Gas Single Oven
Maytag JGW8130DDB12 30" Built - in Gas Single Oven
Jenn-Air JGW8130DDW Walloven - S/c Gas
Whirlpool JGW8130DDW12 30" Built - in Gas Single Oven
Maytag JGW8130DDW12 30" Built - in Gas Single Oven
Jenn-Air JGW9130ADB Walloven - S/c Gas
Jenn-Air JGW9130ADW Walloven - S/c Gas
General Electric JHC56*D1 Hi-low range
General Electric JHC56*VA Hi-low range
General Electric JHC56*VB Hi-low range
General Electric JHC56G*D1 Hi-low range
General Electric JHC56G*D2 Hi-low range
Maytag JHP1060 Commercial Cooking
Maytag JHP112 Commercial Cooking
Maytag JHP212 Commercial Cooking
Maytag JHP224 Commercial Cooking
Maytag JHP336 Commercial Cooking
Maytag JHP424 Commercial Cooking
Maytag JHP448 Commercial Cooking
General Electric JHP56*D1 Hi-low range
General Electric JHP56*V8 Hi-low range
General Electric JHP56*VA Hi-low range
General Electric JHP56G*C1 Hi-low range
General Electric JHP56G*D1 Hi-low range
General Electric JHP56G*D2 Hi-low range
General Electric JHP56G*D3 Hi-low range
General Electric JHP56G*H2 Hi-low range
General Electric JHP56G*J1 Hi-low range
General Electric JHP56G*J2 Hi-low range
General Electric JHP56G*J3 Hi-low range
General Electric JHP56G*M1 Hi-low range
General Electric JHP56G*V6 Hi-low range
General Electric JHP56GN1 Hi-low range
General Electric JHP56GN2 Hi-low range
General Electric JHP56GN3AD Electric range
General Electric JHP56GN3WH Electric range
General Electric JHP56GN4AD Electric range
General Electric JHP56GN4WH Electric range
General Electric JHP56GN5AD Electric range
General Electric JHP56GN5WH Electric range
General Electric JHP56GN6AD Electric range
General Electric JHP56GN6WH Electric range
General Electric JHP56GN7AD Electric range
General Electric JHP56GN7WH Electric range
General Electric JHP56N*K1 Hi-low range
General Electric JHP56N*K2 Hi-low range
General Electric JHP56N*K3 Hi-low range
General Electric JHP56N*K4 Hi-low range
General Electric JHP56V*K1 Hi-low range
General Electric JHP56V*K2 Hi-low range
General Electric JHP56V*K3 Hi-low range
General Electric JHP56V*K4 Hi-low range
General Electric JHP60G*01 Hi-low range
General Electric JHP60G*02 Hi-low range
General Electric JHP60G*03 Hi-low range
General Electric JHP60G*04 Hi-low range
General Electric JHP61G*H2 Hi-low range
General Electric JHP61G*J1 Hi-low range
General Electric JHP62G*M1 Hi-low range
General Electric JHP62GN1 Electric range
General Electric JHP62GN2 Hi-low range
General Electric JHP62GN3AD Electric range
General Electric JHP62GN3WH Electric range
General Electric JHP62GN4AD Electric range
General Electric JHP62GN4WH Electric range
General Electric JHP62GN5AD Electric range
General Electric JHP62GN5WH Electric range
General Electric JHP62GN6AD Electric range
General Electric JHP62GN6WH Electric range
General Electric JHP62N*K1 Hi-low range
General Electric JHP62N*K2 Hi-low range
General Electric JHP62N*K3 Hi-low range
General Electric JHP62N*K4 Hi-low range
General Electric JHP62N*K5 Hi-low range
General Electric JHP62V*K1 Hi-low range
General Electric JHP62V*K2 Hi-low range
General Electric JHP62V*K3 Hi-low range
General Electric JHP62V*K4 Hi-low range
General Electric JHP62V*K5 Hi-low range
Maytag JHP636 Commercial Cooking
General Electric JHP63G*H1 Hi-low range
General Electric JHP63G*J1 Hi-low range
General Electric JHP63G*J2 Hi-low range
General Electric JHP63G*J3 Hi-low range
General Electric JHP63G*M1 Hi-low range
General Electric JHP63GN1 Electric range
General Electric JHP63GN2 Hi-low range
General Electric JHP63GN3AD Electric range
General Electric JHP63GN3WH Electric range
General Electric JHP63GN4AD Electric range
General Electric JHP63GN4WH Electric range
General Electric JHP63GN5AD Electric range
General Electric JHP63GN5WH Electric range
General Electric JHP63V*K1 Hi-low range
General Electric JHP63V*K2 Hi-low range
General Electric JHP63V*K3 Hi-low range
General Electric JHP63V*K4 Hi-low range
General Electric JHP63V*K5 Hi-low range
General Electric JHP64G*L1 Hi-low range
General Electric JHP64V*L1 Hi-low range
General Electric JHP65G*01 Hi-low range
General Electric JHP65G*02 Hi-low range
General Electric JHP65G*D1 Hi-low range
General Electric JHP66G*01 Hi-low range
General Electric JHP66G*02 Hi-low range
General Electric JHP67G*D1 Hi-low range
General Electric JHP67G*D2 Hi-low range
General Electric JHP67G*D3 Hi-low range
General Electric JHP67G*H2 Hi-low range
General Electric JHP67G*V5 Hi-low range
General Electric JHP68G*01 Hi-low range
General Electric JHP68G*02 Hi-low range
General Electric JHP69G*H2 Hi-low range
General Electric JHP69G*J1 Hi-low range
General Electric JHP69G*K1 Hi-low range
General Electric JHP69G*K2 Hi-low range
General Electric JHP69G*K3 Hi-low range
General Electric JHP69G*K4 Hi-low range
General Electric JHP69G*K5 Hi-low range
  #2 (permalink)
Old 07-22-2010, 12:26 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Many thanks
Yes , your oven can be resurrected,you may not need a part at all.
Check and make sure your breakers(fuses) are reset(not blown).
You will need to remove the unit from the cabinet and make sure the wire connections are'nt burnt, loose or damaged, and you have 220 to 240 volts at the oven wire connector on the back .
You may have a damaged control assembly but do those other checks or repairs first.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven hit by voltage surge adons Oven Repair (including Ranges and Cooktops) 0 07-22-2010 11:01 AM
Surge kills oven adons Oven Repair (including Ranges and Cooktops) 0 05-04-2010 10:48 AM
60's Thermador double oven - low voltage doublebubble Oven Repair (including Ranges and Cooktops) 2 04-05-2010 07:58 AM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
how important is oven voltage? anders5401 Oven Repair (including Ranges and Cooktops) 1 12-16-2008 11:48 AM
