Discuss
Dual Infinite Switch Replacement
 in
Originally Posted by drazlou OK. Thanks for the help and the schematic. I'll give it a try and let you
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dual Infinite Switch Replacement
  #71 (permalink)
Old 08-09-2017, 11:27 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by drazlou View Post
OK. Thanks for the help and the schematic. I'll give it a try and let you know.
Drazlou,
OK, Sounds like a deal to me.
Just remember, the wire colors may be different, but the terminals and connections will be the same at the element and the new switch(per the previous wiring information). Will keep an eye out for your next post, Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #72 (permalink)
Old 08-09-2017, 12:15 PM
Junior Member
drazlou is on a distinguished road
Default
Just looking at the schematic I see my error. I guessed that the blue wire on the left switch served the same purpose as the yellow on the right switch and connected it is if it was the outside burner. Its actually purple and is the common burner wire. The way I have it hooked up both burners are in series when I select the inner burner only which is why it's dim and voltage only to the outer burner when I select both burners. Thanks!
  #73 (permalink)
Old 08-09-2017, 12:19 PM
Senior Expert
Default
Dazlou, You're Very Welcome !!!
Good Luck,
__________________
Joe M. APP TEAM
  #74 (permalink)
Old 08-10-2017, 03:48 AM
Junior Member
Default
Rewired the three burner wires per the schematic and it works fine. Thanks again for the help.
  #75 (permalink)
Old 08-10-2017, 06:11 AM
Senior Expert
Default
Drazlou,
GREAT !!!
Glad you didn't damage anything. When you mis wire that switch, quite often
it'll short out the internal contacts and it will need to be replaced. Thanks Again, Great job.
__________________
Joe M. APP TEAM
  #76 (permalink)
Old 09-13-2017, 04:38 PM
Junior Member
w2012z is on a distinguished road
Default my stove : JES9800ACB
I have a quick question. I have read the thread on the first page for the JES9800AAW. You say to connect the jumper wire from P1 to S1. On the switch I just ordered (part 12002125) there are two(2) P1 connector very close together. In which P1 connector should I connect the wire (see attached image)? The one on the left or the right (when the back switch is facing you)
Thank you
  #77 (permalink)
Old 09-14-2017, 04:00 AM
Junior Member
Default
Both are interconnected so it doesn't matter which terminal you put the jumper on. Use whichever one works better for you when you you have to connect all the other wires.
  #78 (permalink)
Old 09-14-2017, 09:20 AM
Senior Expert
Default
Drazlou, Correct, it really doesn't matter which P1 terminal you use for the jumper wire. Always found it easier to install the jumper wire first, right out of the bag, then transfer and attach the wires to the switch terminals as directed in the instructions. If the red wire(s) need to be separated and attached to specific terminals, save that for last. Recheck all the connections, restore power, then test the switch and element operation*CAREFULLY*. Remove power and restore the product to operation, and recheck one more time.
__________________
Joe M. APP TEAM
  #79 (permalink)
Old 09-18-2017, 09:33 AM
Junior Member
Default
Thank you. Everything is now working.
  #80 (permalink)
Old 09-18-2017, 11:12 AM
Senior Expert
Default
Quote:
GREAT !!! We're glad you worked it out, and you're machine is up and running. Great Job. We're here if you need us. Thanks Again,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dual Infinite Switch Wiring stewmcd Oven Repair (including Ranges and Cooktops) 29 05-28-2018 03:26 PM
Wiring for dual infinite switch captain stan Oven Repair (including Ranges and Cooktops) 0 05-16-2009 02:37 PM
Dual Infinite Switch Replacement david.freeland@sacorp.com Oven Repair (including Ranges and Cooktops) 1 09-24-2008 03:30 PM
Replacing Dual Infinite Switch on Range juchunk Oven Repair (including Ranges and Cooktops) 0 05-02-2008 07:51 AM
Infinite Wire Switch Dual Element leighr3 Oven Repair (including Ranges and Cooktops) 1 12-11-2007 01:04 PM
