Register | FAQ's | New Posts | Today's Posts | Extras |
» Dual Infinite Switch Replacement |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Quote:
First install the jumper wire from one P1 terminal and the S1 terminal(it's easier that way). The Double back wire(L1 comm. to all the burner switches) goes on the other P1 terminal. The tan-blue wire( to the inner ring of the element) will attach to terminal 4. The orange-blue wire( to the outer ring of the element) will attach to terminal 4A. The Black wire (to the indicator light)will attach to the S2 terminal. The Double red wire(comm. to all the burner switches) will attach to the P2 terminal. The single red wire(comm. to both element rings)will attach to terminal 2. (like I mentioned before, you may have to check the blue wire you mentioned, to se which element ring it is attached to and attach it to the appropriate terminal on the new switch. But you should be fine from there.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
![]() That is how I wired both switches. The right switch works fine but the left switch only powers the outer element when on both burners high setting. Also the outer element stays on for a brief period then goes off. It keeps cycling like this. The inner element glows faintly like it's on reduced voltage even on the high setting.
![]() Drazlou, the element isn't in question. The question is, the wire colors, to the element rings/ribbons. The wiring diagram indicates a tan and orange wires to the individual element terminals, you stated you have a blue wire to the element. you'll need to know which element(inner or outer) terminal it attaches to so you can attach the other end to the proper terminal on the new switch (4 or 4A). Once you determine the element terminals, wire the remainder of the terminals according to the previous post, and you'll be fine.
__________________
![]() Quote:
__________________
![]() Drazlou, No, splitting the double staked red wires on you model isn't necessary. The single red wire to terminal 2 is sufficient to operate the "common " L2 power out to the element. We wouldn't recommend you remove or "swap" switches, just to check the operation. You'd want to recheck the wiring locations on the new switch, also trace the blue wire to the terminal point on the element and make sure you attach it to the proper terminal on the new switch (use the previous wiring information we sent, and the attached wiring diagram to trace and verify the wiring). If the issue persists then replace the infinite switch again.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Dual Infinite Switch Wiring | stewmcd | Oven Repair (including Ranges and Cooktops) | 28 | 03-07-2016 05:54 PM |
Wiring for dual infinite switch | captain stan | Oven Repair (including Ranges and Cooktops) | 0 | 05-16-2009 02:37 PM |
Dual Infinite Switch Replacement | david.freeland@sacorp.com | Oven Repair (including Ranges and Cooktops) | 1 | 09-24-2008 03:30 PM |
Replacing Dual Infinite Switch on Range | juchunk | Oven Repair (including Ranges and Cooktops) | 0 | 05-02-2008 07:51 AM |
Infinite Wire Switch Dual Element | leighr3 | Oven Repair (including Ranges and Cooktops) | 1 | 12-11-2007 01:04 PM |
