Discuss
Whirlpool F6 E2 now F5 E1
 in
Whirlpool Model [FONT='Calibri','sans-serif'] RDB245PDQ14 that had intermittent F6 E2 error. Just changed the control board and display reads F5 E1
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool F6 E2 now F5 E1
  #1 (permalink)
Old 07-20-2010, 08:31 AM
Junior Member
Tool1967 is on a distinguished road
Default Whirlpool F6 E2 now F5 E1
Model Number: RDB245PDQ14   Brand: Whirlpool   Age: 1 - 5 years
Whirlpool Model [FONT='Calibri','sans-serif']RDB245PDQ14 that had intermittent F6 E2 error. Just changed the control board and display reads F5 E1 If i cycle the power I occasionally get F3 E1. Put old control board in and no error codes. Any thoughts? [/font]
[FONT='Calibri','sans-serif']Thanks, not much hair left to pull out [/font]
Related Models
Thermador RDDS30
Thermador RDDS30 PRIOR TO S/N 9707
Thermador RDDS30 S/N 9707 & UP
Thermador RDDS30QW PRIOR TO S/N 9708
Thermador RDDS30QW S/N 9708 & UP
Thermador RDDS30V RANGE
Thermador RDDS30VQB PRIOR TO S/N 9707
Thermador RDDS30VQB S/N 9707 & UP
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Roper RDE22302 ELECTRIC RANGES AND OVENS
Whirlpool RDE32302
Thermador RDF30 30" DUAL-FUEL RANGE
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Jenn-Air RDK100W MISC / ACCESSORY
Jenn-Air RDK226W MISC / ACCESSORY
Jenn-Air RDK246W MISC / ACCESSORY
Roper RDP34502 ELECTRIC RANGE AND OVEN
Whirlpool RDP34582
Amana RDS-648-UK RANGE- S/C S/I DDRAFT GAS
Thermador RDSS30 S/N 9707 & UP
General Electric RE101101 Electric range
General Electric RE101102 Electric range
General Electric RE101103 Electric range
General Electric RE102101 Electric range
General Electric RE102102 Electric range
General Electric RE102103 Electric range
Whirlpool RE123 Air-conditioner/heat pump
Whirlpool RE123A1 Air-conditioner/heat pump
Whirlpool RE123A2 AIR CONDITIONERS
Whirlpool RE123F0 AIR CONDITIONER
Whirlpool RE123G0 AIR CONDITIONER
Amana RE14010C2D ROOM AIR CONDITIONER
Amana RE14010C2D REV ROOM AIR CONDITIONER
Amana RE14010C2DR ROOM AIR CONDITIONER
Amana RE14010C2DR REV ROOM AIR CONDITIONER
General Electric RE140901 Electric range
General Electric RE1409G01 Electric range
General Electric RE1409G02 Electric range
General Electric RE141001 Electric range
General Electric RE142001 Electric range
General Electric RE144001 Electric range
General Electric RE1440G01 Electric range
General Electric RE1440G02 Electric range
General Electric RE1440H01 Electric range
General Electric RE1440H02 Electric range
General Electric RE145001 Electric range
General Electric RE1450G01 Electric range
General Electric RE1450G02 Electric range
General Electric RE1450H01 Electric range
General Electric RE1450H02 Electric range
Amana RE18010C2D ROOM AIR CONDITIONER
Amana RE18010C2D REV ROOM AIR CONDITIONER
Amana RE18010C2DR ROOM AIR CONDITIONER
Amana RE18010C2DR REV ROOM AIR CONDITIONER
Amana RE18090C2D ROOM AIR CONDITIONER
Amana RE18090C2D REV ROOM AIR CONDITIONER
Amana RE18090C2DR ROOM AIR CONDITIONER
Amana RE18090C2DR REV ROOM AIR CONDITIONER
Whirlpool RE183 Air-conditioner/heat pump
Whirlpool RE183A AIR CONDITIONER
Whirlpool RE183A1 AIR CONDITIONER
Whirlpool RE183A2 AIR CONDITIONER
Whirlpool RE183A3 AIR CONDITIONER
Whirlpool RE183G0 AIR CONDITIONER
Whirlpool RE243K0 ROOM AIR CONDITIONER
Whirlpool RE253E AIR CONDITIONER
Whirlpool RE253F0 AIR CONDITIONER
Whirlpool RE253G1 AIR CONDITIONER
Frigidaire RE32BNL1 Frg(v2) / Electric Range
Frigidaire RE32BNL2 Frg(v2) / Electric Range
Frigidaire RE32BNM1 Frg(v3) / Electric Range
Frigidaire RE32BNW1 Frg(v1) / Electric Range
Frigidaire RE32BNW2 Frg(v1) / Electric Range
Frigidaire RE34BAA3 Frg(v4) / Electric Range
Frigidaire RE34BAA4 Frg(v9) / Electric Range
Frigidaire RE34BAA5 Frg(v3) / Electric Range
Frigidaire RE34BAF3 Frg(v3) / Electric Range
Frigidaire RE34BAF4 Frg(v8) / Electric Range
Frigidaire RE34BAF5 Frg(v2) / Electric Range
Frigidaire RE34BAH2 Frg(v1) / Free Standing Electric Range
Frigidaire RE34BAH3 Frg(v5) / Electric Range
Frigidaire RE34BAH4 Frg(v10) / Electric Range
Frigidaire RE34BAH5 Frg(v4) / Electric Range
Frigidaire RE34BAL2 Frg(v2) / Free Standing Electric Range
Frigidaire RE34BAL3 Frg(v2) / Electric Range
Frigidaire RE34BAL4 Frg(v7) / Electric Range
Frigidaire RE34BAL5 Frg(v5) / Electric Range
  #2 (permalink)
Old 07-20-2010, 09:44 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Did this occur after a self clean cycle or an extensive bake or broil cycle ?
I would suspect a loose connection in the latch and sensor harness that is routed from the control board to the self clean latch assembly switches and the oven temperature sensor(this is one harness that separates and connects to the components).
your codes indicate:
F3-E1 = temperature sensor resistance out of range
F5-E1 = door latch switch position open
F6-E2 = control not recieving door switch return pulse
since your codes have reset after you re installed your old control, this would lead me to believe you have a loose connection in your harness. You may want to trace those wires to the components and insure you have a good, tight connection(s) at the control board and switches at the latch and sensor.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 07-20-2010, 09:57 AM
Junior Member
Default
Thank you for your response. I have never used the self clean feature. The oven died in the middle of a bake session but came back on with F6 E2 which allowed us to clear and finish cooking. I changed the control board after that cooking session.
I checked and cleaned the latch and sensor wires last night. Put a meter on the latch motor per tech sheet and checked out ok. The old control board hasn't shown any error codes since putting it back - though suspect it to die again at worst time. Any chance the new board is bad? very strange.
  #4 (permalink)
Old 07-20-2010, 03:04 PM
Senior Expert
Default
Not much of a chance you had a bad new control(but possible). I would have suspected the wiring from the start, based on the codes and your problem description.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool and Whirlpool Made jtowntbo5@yahoo.com Washer Repair 1 05-12-2009 05:46 PM
