Discuss
Viking spark module - which part ?
 in
I have a 6 burner Viking cooktop VGSU161. The problem I have is that the igniters for the 4 four
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking spark module - which part ?
  #1 (permalink)
Old 07-19-2010, 06:15 PM
Junior Member
lancecowell is on a distinguished road
Default Viking spark module - which part ?
Model Number: VGSU1616BSS   Brand: -other-   Age: 5 - 10 years
I have a 6 burner Viking cooktop VGSU161. The problem I have is that the igniters for the 4 four burners (3 front, 1 left back) fire continuously even with no burners on. I have determined that it is the spark module by swapping the bad module with the other two igniter module also in the cooktop. Works perfectly on the 4 burners (two at a time !). The problem is what part to replace my spark module with. Viking dealer says use PA020047 - a 4 spark module that looks the same as the module PA020020 I have now. However, it appears to be a bit larger, and the dealer says you then can't install the metal cover overe it, and the mounting screws will be in different positions. Is it O.K. to leave the metal cover off - the dealer says so. Alternatively, Gene has previously pointed to a whirlpool part that appears identical to the one I am taking out - just not sure. The whirlpool part number is 4454392.
Which part should I use ? I am tempted to use what the Viking dealer recommends, but I would prefer to be able to install one of the exact same size so that I can install the metal guard. Does it matter if this is left off?
Alternatively could I/Should I switch to a six igniter module - PA020048 ? and get rid of the second igniter ?
Many thanks
Ads By Google
Related Models
Amana VHC-2 Range - S/c S/i Ddraft Gas
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410
Thermador VM-450
Magic Chef VM11A-8P Mwave - Mounted Under Cabinet
Magic Chef VM11B-8P Mwave - Mounted Under Cabinet
Magic Chef VM11B-8PDY Mwave - Mounted Under Cabinet
Magic Chef VM11BN-8P Mwave - Mounted Under Cabinet
Magic Chef VM11C-8P Mwave - Mounted Under Cabinet
Magic Chef VM11CN-8P Mwave - Mounted Under Cabinet
Magic Chef VM11D-8P Mwave - Mounted Under Cabinet
Magic Chef VM11D-8P-DY Mwave - Mounted Under Cabinet
Magic Chef VM11DN-8P Mwave - Mounted Under Cabinet
Magic Chef VM11EB-8P Mwave - Mounted Under Cabinet
Magic Chef VM11EV-8P Mwave - Mounted Under Cabinet
Maytag VM12AB Mwave - Mounted Under Cabinet
Maytag VM12AM Mwave - Mounted Under Cabinet
Maytag VM12AV Mwave - Mounted Under Cabinet
Maytag VM12AV-1 Mwave - Mounted Under Cabinet
Thermador VM410
Magic Chef VM9B-8 Mwave - Mounted Under Cabinet
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000
Thermador VQT600
Whirlpool VR
Thermador VR-1000
Thermador VR-1400
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
Thermador VR1400
Frigidaire VR16
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No spark at burner - is it spark module or switch? Schoeman Oven Repair (including Ranges and Cooktops) 0 05-28-2010 01:18 PM
Replace which part: : igniter, spark module or safety valve? davidinnh Oven Repair (including Ranges and Cooktops) 0 01-06-2010 10:34 AM
Spark Electrode or Spark Module elpokeman Oven Repair (including Ranges and Cooktops) 0 10-22-2009 08:31 PM
spark module ernienorton Oven Repair (including Ranges and Cooktops) 0 09-18-2009 01:58 PM
spark module replacement part sands Oven Repair (including Ranges and Cooktops) 1 08-22-2009 10:33 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
