the oven or broiler will not light. when I press the oven button and raise the temp setting to 325 it appears to act normally but after a few seconds it shows 100 degrees and then it shuts down , the same is true with the broiler. I have changed the relay board Part Number: AP4102784 and it's still not fixed. I want to know if it could be the elecronic controller Part Number: AP4102784
