Discuss
temp in oven is wrong
 in
The oven in the house I'm renting is burning all my meals!!!! I hung an oven thermomter in the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » temp in oven is wrong
  #1 (permalink)
Old 09-13-2007, 05:53 PM
smpmagic smpmagic is offline
Junior Member
smpmagic is on a distinguished road
Unhappy temp in oven is wrong
Model Number: TEF303BWD   Brand: Tappan   Age: 5 - 10 years
The oven in the house I'm renting is burning all my meals!!!! I hung an oven thermomter in the oven and it is reading about 25-50 degrees higher than what it is set for. what could be causing this, and how can I fix it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-13-2007, 10:42 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi smpmagic
To make the right decision it is very important how you measure the temperature in your oven. The thermometer has to be placed in the middle of the oven cavity. Set the thermostat for 350 degrees and do not open the oven door for at least 15 minutes after the oven indicator light will go off. Let me know the thermometer reading.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-02-2007, 02:42 PM
Junior Member
Default
Hi Gene,
I followed your instructions and the thermometer read 400 degrees after the preheat light had been out for about 15 min. Oven temp was set for 350
  #4 (permalink)
Old 12-02-2007, 02:51 PM
Junior Member
Default
Hi Gene,
  #5 (permalink)
Old 12-02-2007, 02:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The difference in 50 degrees is to much for the calibration. In such case the oven thermostat has to be replaced.
- The part number for the oven thermostat AP3559535
__________________
  #6 (permalink)
Old 12-02-2007, 03:21 PM
Junior Member
Default
Thank you Gene
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat to temp docjolly Oven Repair (including Ranges and Cooktops) 0 09-03-2007 09:03 PM
Oven lights and heats to Temp but goes out immediately!! jomo Oven Repair (including Ranges and Cooktops) 0 08-31-2007 10:49 AM
Oven Temp 60F low George Whitmore Oven Repair (including Ranges and Cooktops) 0 08-13-2007 04:08 PM
Oven temp guage starts at 315 degrees RBS Oven Repair (including Ranges and Cooktops) 0 08-10-2007 09:28 PM
Oven wont heat to temp rickm1959 Oven Repair (including Ranges and Cooktops) 1 07-24-2007 04:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
