Nice range, but it seems to have issues with the oven controls. A while back, the digital display went blank, and then came back on. Today, while set in bake mode, it locked the oven door and went into clean mode, which turned the cornbread into charcoal. After I shut down the power and let it cool down, it reset and unlocked the door. It lists two separate control boards, one, called the oven control, is listed with the control panel drawing, the other, called the Zodiak board, is listed on the top venting drawing. How do tell which one is bad? Or, are there other issues with this model I should know about? I also got an error code when it was locked in clean mode: I think it was F 02.
Thanks.
