Discuss
Ignitor successfully replaced but...
 in
Thanks to the experts on this site and appliancepartspros.com I successfully diagnosed and repaired a broken ignitor. However, before I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ignitor successfully replaced but...
  #1 (permalink)
Old 07-15-2010, 11:18 AM
Junior Member
jennsnate is on a distinguished road
Default Ignitor successfully replaced but...
Model Number: 32211XAW   Brand: Magic Chef   Age: More than 10 years
Thanks to the experts on this site and appliancepartspros.com I successfully diagnosed and repaired a broken ignitor. However, before I came across this site I cut the copper wire coming out the back of the oven control knob to completely remove and inspect it (which I now know is the thermostat Part Number: AP4092858) I twisted the wire ends back together but am doubting this is sufficient. The oven works now but only has 2 settings- off and broil, no in between. I have also tried to adjust the small screw in the themostat with no change. Do I need to buy an entire new thermostat, can I just purchase the wire leading to the sensor, or is there someway to correctly re-attach the cut ends?
Help please!
Ads By Google
Related Models
Magic Chef 32211XAW RANGE-F/S CONT CLEAN GAS
Magic Chef 3221WPA RANGE-F/S CONT CLEAN GAS
Magic Chef 3221WPV RANGE-F/S CONT CLEAN GAS
Magic Chef 3221WRV RANGE-F/S CONT CLEAN GAS
Magic Chef 3221WTV RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XPA RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XPS RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XPW RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XRA RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XRS RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XRW RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XTA RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XTS RANGE-F/S CONT CLEAN GAS
Magic Chef 3221XTW RANGE-F/S CONT CLEAN GAS
Magic Chef 3227XRALT4 RANGE-F/S CONT CLEAN GAS
Magic Chef 3227XRWLT4 RANGE-F/S CONT CLEAN GAS
Magic Chef 32315VAM RANGE-F/S CONT CLEAN GAS
Magic Chef 32315VAV RANGE-F/S CONT CLEAN GAS
Magic Chef 32315XAA RANGE-F/S CONT CLEAN GAS
Magic Chef 32315XAW RANGE-F/S CONT CLEAN GAS
Magic Chef 3241XRA RANGE-F/S CONT CLEAN GAS
Magic Chef 3241XRW RANGE-F/S CONT CLEAN GAS
Magic Chef 3241XTA RANGE-F/S CONT CLEAN GAS
Magic Chef 3241XTW RANGE-F/S CONT CLEAN GAS
Magic Chef 3267XRA RANGE-F/S CONT CLEAN GAS
Magic Chef 3267XRW RANGE-F/S CONT CLEAN GAS
Magic Chef 3267XTA RANGE-F/S CONT CLEAN GAS
Magic Chef 3267XTW RANGE-F/S CONT CLEAN GAS
Magic Chef 3267XUA RANGE-F/S CONT CLEAN GAS
Magic Chef 3267XUW RANGE-F/S CONT CLEAN GAS
Magic Chef 3287XUA-N RANGE-F/S CONT CLEAN GAS
Magic Chef 3287XUW-N RANGE-F/S CONT CLEAN GAS
Amana 329-3B ROOM AIR CONDITIONER
Hoover 33
Frigidaire 33-1027-00-01 Tap(v1) / Electric Range
Frigidaire 33-1027-00-02 Tap(v3) / Electric Range
Frigidaire 33-1027-23-01 Tap(v2) / Electric Range
Frigidaire 33-1027-23-02 Tap(v4) / Electric Range
Frigidaire 33-1467-00-01 Tap(v1) / Electric Range
Frigidaire 33-1467-00-02 Tap(v2) / Electric Range
Frigidaire 33-1467-00-03 Tap(v3) / Electric Range
Amana 330.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 330.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 330.003 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 33002 GAS COOKTOP
Frigidaire 33003 GAS COOKTOP
Frigidaire 33004 GAS COOKTOP
Frigidaire 33009 GAS COOKTOP
Hoover 331
Frigidaire 33158-OA FREEZER
Hoover 334
Hoover 336
Frigidaire 33DEMBWAD3 Tap(v1) / Electric Range
Hoover 34
Hoover 341
Magic Chef 3422PRA RANGE- S/C F/S GAS
Magic Chef 3422PRW RANGE- S/C F/S GAS
Magic Chef 3422PVA RANGE- S/C F/S GAS
Magic Chef 3422PVW RANGE- S/C F/S GAS
Magic Chef 3428PVA-D RANGE- S/C F/S GAS
Magic Chef 3428PVW-D RANGE- S/C F/S GAS
Hoover 344
Magic Chef 3442SRA RANGE- S/C F/S GAS
Magic Chef 3442SRW RANGE- S/C F/S GAS
Magic Chef 3442XRA RANGE- S/C F/S GAS
Magic Chef 3442XRW RANGE- S/C F/S GAS
Frigidaire 3448A GAS RANGE
Magic Chef 3448SRA RANGE- S/C F/S GAS
Magic Chef 3448SRW RANGE- S/C F/S GAS
Magic Chef 3448STA RANGE- S/C F/S GAS
Magic Chef 3448STW RANGE- S/C F/S GAS
Magic Chef 3448XPA RANGE- S/C F/S GAS
Magic Chef 3448XPW RANGE- S/C F/S GAS
Magic Chef 3448XRA RANGE- S/C F/S GAS
Magic Chef 3448XRW RANGE- S/C F/S GAS
Magic Chef 3448XTA RANGE- S/C F/S GAS
Magic Chef 3448XTS RANGE- S/C F/S GAS
Magic Chef 3448XTW RANGE- S/C F/S GAS
Magic Chef 3458KVW RANGE- S/C F/S GAS
Magic Chef 3458SVA RANGE- S/C F/S GAS
Magic Chef 3458SVW RANGE- S/C F/S GAS
Magic Chef 3458XVA RANGE- S/C F/S GAS
Magic Chef 3458XVB RANGE- S/C F/S GAS
Magic Chef 3458XVS RANGE- S/C F/S GAS
Magic Chef 3458XVW RANGE- S/C F/S GAS
Hoover 346
Frigidaire 3468A GAS RANGE
Magic Chef 3468VRV RANGE- S/C F/S GAS
Magic Chef 3468VTV RANGE- S/C F/S GAS
Magic Chef 3468VVD RANGE- S/C F/S GAS
Magic Chef 3468VVV RANGE- S/C F/S GAS
Magic Chef 3468XRA RANGE- S/C F/S GAS
Magic Chef 3468XRA-X RANGE- S/C F/S GAS
Magic Chef 3468XRW RANGE- S/C F/S GAS
Magic Chef 3468XRW-X RANGE- S/C F/S GAS
Magic Chef 3468XTA RANGE- S/C F/S GAS
Magic Chef 3468XTA-X RANGE- S/C F/S GAS
Magic Chef 3468XTW RANGE- S/C F/S GAS
Magic Chef 3468XTW-X RANGE- S/C F/S GAS
Magic Chef 3468XVA RANGE- S/C F/S GAS
Magic Chef 3468XVA-X RANGE- S/C F/S GAS
Magic Chef 3468XVB RANGE- S/C F/S GAS
Magic Chef 3468XVW RANGE- S/C F/S GAS
Magic Chef 3468XVW-X RANGE- S/C F/S GAS
Hoover 346A
Hoover 348
Frigidaire 3488A GAS RANGE
Magic Chef 3488VRA RANGE- S/C F/S GAS
Magic Chef 3488VRV RANGE- S/C F/S GAS
Magic Chef 3488VTA RANGE- S/C F/S GAS
Magic Chef 3488VTV RANGE- S/C F/S GAS
Magic Chef 3488VVA RANGE- S/C F/S GAS
Magic Chef 3488VVD RANGE- S/C F/S GAS
Magic Chef 3488VVS-N RANGE- S/C F/S GAS
Magic Chef 3488VVV RANGE- S/C F/S GAS
Magic Chef 3488WVS RANGE- S/C F/S GAS
Magic Chef 3488XPA RANGE- S/C F/S GAS
Magic Chef 3488XPW RANGE- S/C F/S GAS
Magic Chef 3488XRA RANGE- S/C F/S GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ignitor was replaced but only worked 1 day eric n Dryer Repair 0 02-16-2010 01:01 PM
replaced ignitor / didn't lite dan ob Dryer Repair 0 08-22-2009 07:47 AM
Replaced ignitor DeALLEN03 Oven Repair (including Ranges and Cooktops) 2 07-13-2009 08:05 PM
Replaced the correct Ignitor ? tommyboy84 Oven Repair (including Ranges and Cooktops) 7 01-11-2009 12:58 PM
Replaced ignitor worked once then nothing cjkms Oven Repair (including Ranges and Cooktops) 1 08-22-2008 08:51 AM
