Discuss
Broken Bake Element!!
 in
Hi, I have a GE/Hotpoint Electric oven that has worked great for about 15 years or more. A burner started
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broken Bake Element!!
  #1 (permalink)
Old 07-14-2010, 08:14 AM
Junior Member
alpha_mare is on a distinguished road
Default Broken Bake Element!!
Model Number: RB757BC2WH   Brand: Hotpoint   Age: More than 10 years
Hi, I have a GE/Hotpoint Electric oven that has worked great for about 15 years or more. A burner started sparking and so I replaced all the burner plugs, but didn't do the switches. One switch must be bad because the burner light is on all the time even though the burner is switched off. We disconnected the wires to that burner and capped them.
Then, one of my boys used the oven and promptly informed me that I should throw my stove away because the oven wasnt getting hot enough. Iopened the door and a three inch segment of the bake element had broken off and there was white powder on the door and floor of the oven.
I'm not worried about putting in a new bake element (this is a self cleaning oven and is old). Working on this stove has not been hard so far and it still looks new.
What do I need to worry about replacing, just the element or is it a sign of a bigger problem? Should I replace the burner element on the effected burner when I replace the switch? Most of the plug-ins were very loose or cracked beforeI replaced them.
Thanks for any help you can give. I'm really poor and I can't afford a new stove. I've had this one since new.
Ads By Google
Related Models
General Electric RB757BC2WH Electric range
General Electric RB757BC3AD Electric range
General Electric RB757BC3CT Electric range
General Electric RB757BC3WH Electric range
General Electric RB757BC4WH Electric range
General Electric RB757BH1CT Electric range
General Electric RB757BH1WH Electric range
General Electric RB757BH2CT Electric range
General Electric RB757BH2WH Electric range
General Electric RB757BH3CT Electric range
General Electric RB757BH3WH Electric range
General Electric RB757BH4CT Electric range
General Electric RB757BH4WH Electric range
General Electric RB757CH1CC Electric range
General Electric RB757CH2CC Electric range
General Electric RB757CH3CC Electric range
General Electric RB757CH4CC Electric range
General Electric RB757EH1BB Electric range
General Electric RB757EH2BB Electric range
General Electric RB757EH3BB Electric range
General Electric RB757EH4BB Electric range
General Electric RB757GN1 Electric range
General Electric RB757GN2 Electric range
General Electric RB757GN3 Electric range
General Electric RB757GN4AD Electric range
General Electric RB757GN4WH Electric range
General Electric RB757GN5AD Electric range
General Electric RB757GN5WH Electric range
General Electric RB757GN6AD Electric range
General Electric RB757GN6WH Electric range
General Electric RB757GT1AD Electric range
General Electric RB757GT1WH Electric range
General Electric RB757GT2AD Electric range
General Electric RB757GT2WH Electric range
General Electric RB757GT3AD Electric range
General Electric RB757GT3WH Electric range
General Electric RB757GT4AD Electric range
General Electric RB757GT4WH Electric range
General Electric RB757GV1AD Electric range
General Electric RB757GV1WH Electric range
General Electric RB757WB1 Electric range
General Electric RB757WC1WW Electric range
General Electric RB757WC2WW Electric range
General Electric RB757WC3WW Electric range
General Electric RB757WC4WW Electric range
General Electric RB757WH1WW Electric range
General Electric RB757WH2WW Electric range
General Electric RB757WH3WW Electric range
General Electric RB757WH4WW Electric range
General Electric RB757WT1WW Electric range
General Electric RB757WT2WW Electric range
General Electric RB757WT3WW Electric range
General Electric RB757WT4WW Electric range
Whirlpool RB760PXBB0
Whirlpool RB760PXBB1
Whirlpool RB760PXBB2
Whirlpool RB760PXBQ0
Whirlpool RB760PXBQ1
Whirlpool RB760PXBQ2
Whirlpool RB760PXT0
Whirlpool RB760PXT1
Whirlpool RB760PXT2
Whirlpool RB760PXXB0
Whirlpool RB760PXXB1
Whirlpool RB760PXXB2
Whirlpool RB760PXXW0
Whirlpool RB760PXXW1
Whirlpool RB760PXYB0
Whirlpool RB760PXYB2
Whirlpool RB760PXYB3
Whirlpool RB760PXYB4
Whirlpool RB760PXYB5
Whirlpool RB760PXYB6
Whirlpool RB760PXYQ0
Whirlpool RB760PXYQ2
Whirlpool RB760PXYQ3
Whirlpool RB760PXYQ4
Whirlpool RB760PXYQ5
Whirlpool RB760PXYQ6
General Electric RB761G*N1 Electric range
General Electric RB767GN1 Electric range
General Electric RB767GN2 Electric range
General Electric RB767GN3 Electric range
General Electric RB767GN4AD Electric range
General Electric RB767GN4WH Electric range
General Electric RB767GN5AD Electric range
General Electric RB767GN5WH Electric range
General Electric RB768GN1 Electric range
Whirlpool RB770PXBB0
Whirlpool RB770PXBB1
Whirlpool RB770PXBB2
Whirlpool RB770PXBQ0
Whirlpool RB770PXBQ1
Whirlpool RB770PXBQ2
Whirlpool RB770PXT0
Whirlpool RB770PXT1
Whirlpool RB770PXT2
Whirlpool RB770PXXB0
Whirlpool RB770PXXB1
Whirlpool RB770PXXB3
Whirlpool RB770PXXB4
Whirlpool RB770PXXW0
Whirlpool RB770PXXW2
Whirlpool RB770PXXW3
Whirlpool RB770PXYB0
Whirlpool RB770PXYB2
Whirlpool RB770PXYB3
Whirlpool RB770PXYB4
Whirlpool RB770PXYB5
Whirlpool RB770PXYB6
Whirlpool RB770PXYB7
Whirlpool RB770PXYQ0
Whirlpool RB770PXYQ2
Whirlpool RB770PXYQ3
Whirlpool RB770PXYQ4
Whirlpool RB770PXYQ5
Whirlpool RB770PXYQ6
Whirlpool RB770PXYQ7
General Electric RB787BB1BB Electric range
General Electric RB787BC1BB Electric range
  #2 (permalink)
Old 07-15-2010, 03:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the range out of the wall. Remove the rear panel. Remove the wires from the Bake element and check for 240 VAC between these wires while the control calls for Bake.
If there is proper voltage, replace the Bake element and it should be good.
If the voltage is incorrect, most likely the control board got damaged by the shorted Bake element and has to be replaced as well.
Regarding the surface burner problem, I believe that the new switch will fix it.
- The Bake element Part number: AP2030964
- The control board Part number: AP2025090
You have to order the overlay for the control board because it's glued on. If you need the correct part number for the overlay, post the color of it.
There are two different infinite switches used in this range and the part number depends on the size of the burner.
Here are the breakdown diagrams and Replacement parts for General Electric RB757BC2WH Electric range | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-15-2010, 09:33 PM
Junior Member
Default
Thanks, Gene. I hope I don't need all that. Hopefully its just the element. Thanks on the switch info. Once the chaos stops, I want
to get all new burner elements. I just can't afford them right now. But after what happened to my bake element, its definitely moved up on the list.
Thanks on the burner, its the 8". I imagine with it being selfcleaning, the bake elements do go bad with that high heat.
After all this (I replaced the sealon the oven door too) my stove will be brand new!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced upper broil element, lower bake element. Elements still not working bumdout Oven Repair (including Ranges and Cooktops) 1 11-25-2009 02:49 PM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
broken bake element essies Oven Repair (including Ranges and Cooktops) 0 10-27-2009 07:54 AM
Replaced bake element, now won't bake/broil mvwa Oven Repair (including Ranges and Cooktops) 0 10-18-2009 12:55 PM
Bake Element and BAKE cycle not working jeffman Oven Repair (including Ranges and Cooktops) 1 08-04-2007 10:18 PM
