Discuss
f2 error code hotpoint range
 in
I have the f2 error code and the oven temperature is lower by several hundred degrees than the broil temperature
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » f2 error code hotpoint range
  #1 (permalink)
Old 08-05-2008, 03:08 PM
honeypot honeypot is offline
Junior Member
honeypot is on a distinguished road
Default f2 error code hotpoint range
Model Number: rgb745beh4wh   Brand: Hotpoint   Age: 1 - 5 years
I have the f2 error code and the oven temperature is lower by several hundred degrees than the broil temperature or oven temperature setting before the oven shuts off with the f2 error code. If i reset the oven by cycling the power the oven works for a while at a low temperature then shuts off with the f2 code. It shuts off faster when trying to broil. The resistance measurement on the oven sensor was within the specs so i replaced the clock but no change in the f2 code. Any ideas? Should I replace the oven sensor any way or is it possible i got a defective clock or could it be something else?
Related Models
General Electric RGB745BEH4WH Gas range
General Electric RGB745BEH5CT Gas range
General Electric RGB745BEH5WH Gas range
General Electric RGB745BEH6CT Gas range
General Electric RGB745BEH6WH Gas range
General Electric RGB745BEH7CT Gas range
General Electric RGB745BEH7WH Gas range
General Electric RGB745EEH1BB Gas range
General Electric RGB745EEH2BB Gas range
General Electric RGB745EEH3BB Gas range
General Electric RGB745EEH4BB Gas range
General Electric RGB745EEH5BB Gas range
General Electric RGB745GEH1 Gas range
General Electric RGB745GEN1 Gas range
General Electric RGB745GER1 Gas range
General Electric RGB745GER2 Gas range
General Electric RGB745GER3 Gas range
General Electric RGB745GES1 Gas range
General Electric RGB745GET1AD Gas range
General Electric RGB745GET1WH Gas range
General Electric RGB745GET2AD Gas range
General Electric RGB745GET2WH Gas range
General Electric RGB745GEV1AD Gas range
General Electric RGB745GEV1WH Gas range
General Electric RGB745GEV2AD Gas range
General Electric RGB745GEV2WH Gas range
General Electric RGB745GEV3AD Gas range
General Electric RGB745GEV3WH Gas range
General Electric RGB745SEV1AD Gas range
General Electric RGB745SEV1WH Gas range
General Electric RGB745SEV2AD Gas range
General Electric RGB745SEV2WH Gas range
General Electric RGB745WEA1WW Gas range
General Electric RGB745WEA2WW Gas range
General Electric RGB745WEA3WW Gas range
General Electric RGB745WEA4WW Gas range
General Electric RGB745WEA5WW Gas range
General Electric RGB745WEA6WW Gas range
General Electric RGB745WEA7WW Gas range
General Electric RGB745WEA8WW Gas range
General Electric RGB745WEH1WW Gas range
General Electric RGB745WEH2WW Gas range
General Electric RGB745WEH3WW Gas range
General Electric RGB745WEH4WW Gas range
General Electric RGB745WEH5WW Gas range
General Electric RGB745WEH6WW Gas range
General Electric RGB745WEH7WW Gas range
General Electric RGB745WET1WW Gas range
General Electric RGB745WET2WW Gas range
General Electric RGB745WEV1WW Gas range
General Electric RGB745WEV2WW Gas range
General Electric RGB745WEV3WW Gas range
General Electric RGB746GEJ1 Gas range
General Electric RGB746GEJ2 Gas range
General Electric RGB746GEJ3 Gas range
General Electric RGB746GEJ4 Gas range
General Electric RGB746GEJ5 Gas range
General Electric RGB746GEJ6 Gas range
General Electric RGB746GEJ7 Gas range
General Electric RGB746GEJ8 Gas range
General Electric RGB746GEJ9 Gas range
General Electric RGB746GEJA Gas range
General Electric RGB746GEN1 Gas range
General Electric RGB746GES1 Gas range
General Electric RGB746HED1CT Gas range
General Electric RGB746HED1WH Gas range
General Electric RGB746HED2CT Gas range
General Electric RGB746HED2WH Gas range
General Electric RGB746HED3CT Gas range
General Electric RGB746HED3WH Gas range
General Electric RGB746HEH1CT Gas range
General Electric RGB746HEH1WH Gas range
General Electric RGB746WEH1WW Gas range
General Electric RGB746WEH2WW Gas range
General Electric RGB746WEH3WW Gas range
General Electric RGB746WEH4WW Gas range
General Electric RGB746WEH5WW Gas range
General Electric RGB746WEH6WW Gas range
General Electric RGB747GEP1 Gas range
General Electric RGB747GER1 Gas range
General Electric RGB747GER2 Gas range
General Electric RGB747GER3 Gas range
General Electric RGB750SEY1WW Gas range
General Electric RGB751GEL1 Electric range
General Electric RGB790BEK1BB Gas range
General Electric RGB790CEK1CC Gas range
General Electric RGB790SEH1SA Gas range
General Electric RGB790SEH2SA Gas range
General Electric RGB790SEH3SA Gas range
General Electric RGB790SEH4SA Gas range
General Electric RGB790SEH5SA Gas range
General Electric RGB790WEK1WW Gas range
General Electric RGB845BEC1WH Gas range
General Electric RGB845BEC2WH Gas range
General Electric RGB845BEC3WH Gas range
General Electric RGB845WEC1WW Gas range
General Electric RGB845WEC2WW Gas range
General Electric RGB845WEC3WW Gas range
General Electric RGB845WEC4WW Gas range
General Electric RGB845WEC5WW Gas range
Frigidaire RGC32BAH1 Frg(v16) / Free Standing Electric Range
Frigidaire RGC32BAH2 Frg(v2) / Electric Range
Frigidaire RGC32BAH3 Frg(v2) / Electric Range
Frigidaire RGC32BAH4 Frg(v5) / Electric Range
Frigidaire RGC32BAL1 Frg(v17) / Free Standing Electric Range
Frigidaire RGC32BAL2 Frg(v3) / Electric Range
Frigidaire RGC32BAL3 Frg(v3) / Electric Range
Frigidaire RGC32BAL4 Frg(v6) / Electric Range
Frigidaire RGC32BAW1 Frg(v18) / Free Standing Electric Range
Frigidaire RGC32BAW2 Frg(v1) / Electric Range
Frigidaire RGC32BAW3 Frg(v1) / Electric Range
Frigidaire RGC32BAW4 Frg(v4) / Electric Range
Frigidaire RGC32BNL1 Frg(v2) / Electric Range
Frigidaire RGC32BNL2 Frg(v2) / Electric Range
Frigidaire RGC32BNW1 Frg(v1) / Electric Range
Frigidaire RGC32BNW2 Frg(v1) / Electric Range
Whirlpool RGC3422AL0
Whirlpool RGC3422AW0
Whirlpool RGC3622BL0
Whirlpool RGC3622BW0
  #2 (permalink)
Old 08-05-2008, 04:39 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
At the back of the oven the sensor wire connects to the erc wireing via a plug, cut out that plug, and hard wire the ends together, frequently that plugs connection is not tight enough, and will result in F2, if that does not fix it, replace the sensor.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-05-2008, 04:49 PM
Junior Member
Default hard wire
well if the oven sensor resistance is measured at around 1000 ohms at the erc
wouldn't this indicate the wiring was okay and not need to be hardwired at the plug at the back of the oven?
  #4 (permalink)
Old 08-05-2008, 05:58 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
No, the heat from the oven can change the values at the plug. Starting with the free and easy things to try is always better than throwing money at it hoping it will work.
__________________
  #5 (permalink)
Old 11-27-2008, 08:02 AM
tycozz tycozz is offline
Junior Member
tycozz is on a distinguished road
Default
I have a Hotpoint mondel number rgb791seh2sa. the oven will not heat
to correct temp. the display unit show a F2 in the window. What is F2?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 Error code on whirlpool Range Larry56 Oven Repair (including Ranges and Cooktops) 3 10-11-2009 10:29 AM
WP Range Error Code E2/F3 go2geye Oven Repair (including Ranges and Cooktops) 1 04-24-2008 11:05 PM
Kenmore Range error code F2-E0 mtfurtney Oven Repair (including Ranges and Cooktops) 1 01-28-2008 11:27 AM
F2 Error Code for Kenmore Range familykg Oven Repair (including Ranges and Cooktops) 1 01-21-2008 01:46 PM
F3 Error code on whirlpool Range alex8469618 Oven Repair (including Ranges and Cooktops) 0 10-09-2007 03:18 PM
