Discuss
f2 error code hotpoint range
 in
I have the f2 error code and the oven temperature is lower by several hundred degrees than the broil temperature
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » f2 error code hotpoint range
  #1 (permalink)
Old 08-05-2008, 03:08 PM
honeypot honeypot is offline
Junior Member
honeypot is on a distinguished road
Default f2 error code hotpoint range
Model Number: rgb745beh4wh   Brand: Hotpoint   Age: 1 - 5 years
I have the f2 error code and the oven temperature is lower by several hundred degrees than the broil temperature or oven temperature setting before the oven shuts off with the f2 error code. If i reset the oven by cycling the power the oven works for a while at a low temperature then shuts off with the f2 code. It shuts off faster when trying to broil. The resistance measurement on the oven sensor was within the specs so i replaced the clock but no change in the f2 code. Any ideas? Should I replace the oven sensor any way or is it possible i got a defective clock or could it be something else?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-05-2008, 04:39 PM
abadfish66's Avatar
abadfish66 abadfish66 is online now
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
At the back of the oven the sensor wire connects to the erc wireing via a plug, cut out that plug, and hard wire the ends together, frequently that plugs connection is not tight enough, and will result in F2, if that does not fix it, replace the sensor.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-05-2008, 04:49 PM
Junior Member
Default hard wire
well if the oven sensor resistance is measured at around 1000 ohms at the erc
wouldn't this indicate the wiring was okay and not need to be hardwired at the plug at the back of the oven?
  #4 (permalink)
Old 08-05-2008, 05:58 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
No, the heat from the oven can change the values at the plug. Starting with the free and easy things to try is always better than throwing money at it hoping it will work.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WP Range Error Code E2/F3 go2geye Oven Repair (including Ranges and Cooktops) 1 04-24-2008 11:05 PM
Kenmore Range error code F2-E0 mtfurtney Oven Repair (including Ranges and Cooktops) 1 01-28-2008 11:27 AM
F2 Error Code for Kenmore Range familykg Oven Repair (including Ranges and Cooktops) 1 01-21-2008 01:46 PM
F3 Error code on whirlpool Range alex8469618 Oven Repair (including Ranges and Cooktops) 0 10-09-2007 03:18 PM
F3 Error code on whirlpool Range Larry56 Oven Repair (including Ranges and Cooktops) 1 09-10-2007 07:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
